| Home > Beginners Tech > fuel pump and ultralight flywheel | |||||||
4th Nov, 2008 at 07:35:33pm
im looking at the minisport ultralight flywheel. i will be using a pre verto clutch setup. can anyone advise whether an ultralight flywheel will be suitable for a road car? i have a cooper mpi for my every day car, so its not as if il be stuck in a lot of traffic in the turbo
4th Nov, 2008 at 07:36:42pm
also using grey diaphragm, standard pressure plate and ap fast road clutch plate. cheers |
547 Posts Member #: 2928 Post Whore peterborough |
4th Nov, 2008 at 08:43:03pm
judging by the fact you said your running 10psi i guess your going to use a sucker or blower. not sure on a sucker but on a blower a facet fast raod pump will not be high neough pressure for a turbo set up to run right, keep the spi pump that should work better
Jack Jones |
4th Nov, 2008 at 08:44:24pm
standard metro turbo t3. its a non injection car so not sure if i can retain original pump |
4th Nov, 2008 at 08:45:23pm
spi pump will be fine for 10psi |
4th Nov, 2008 at 08:52:02pm
a metro turbo fuel pump runs at three bar
Jack Jones |
4th Nov, 2008 at 08:57:32pm
i hope you have not forgot about the pistons and sorting your compression ration lower jack.
4th Nov, 2008 at 09:16:48pm
so use the spi pump instead of facet?
4th Nov, 2008 at 10:44:28pm
A turbo engine with a UL flywheel will idle perfecly at 1000rpm. It depends on camshaft of course, but it will with a Ph2 ie. On 13th Jul, 2012 Ben H said:
4th Nov, 2008 at 11:41:53pm
so guess thats the case for swiftune as well? cheers |
5th Nov, 2008 at 09:35:45am
I've got an ultralight flywheel, and really It doesn't seem much different to the standard one, in terms of pulling away, idling etc.
5th Nov, 2008 at 12:03:17pm
a facet pump WILL NOT work with a turbo unless its suck through.
5th Nov, 2008 at 12:04:09pm
oh yeah and an ultralight will be fine. mine idles perfectly with a PH2 cam in it when it hasnt chewed a plug |
5th Nov, 2008 at 12:04:33pm
and thats with 1.5 roller rockers. |
5th Nov, 2008 at 12:27:10pm
cheers. a pressure regulator is one of the last things on my list. theres a guy on ebay selling them for £60 new i think, am thinking about posting a wanted ad here.
