Home > Help Needed / General Tech Chat > Golf Radiator
Anyone running an early VW Golf radiator up front?
Some of the Miglias run them and a quick search through ebay shows lots available at a good price.
Best bit is the inlet and outlet on the same side.
EDIT: Core Dimensions are 525mm long, 320mm high and 33mm thick.
Edited by Paul S on 5th Nov, 2008.
have a look at the mk2 clio rads aswell.
inlet and outlet same side and a decent size. possibly a bit tall maybe but who knows.
Ollie
Member #: 1380
wow, cheers paul thats a very handy bit of info - you even supplied the dimensions too!! *happy*
i'm going to have to measure up at some point during my build now to see if i can get a front mounted rad in there.
when you say early are you talking mk1 / mk2?
I was looking at this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWA:IT&ih=010
Clio looks interesting, although a bit tall.
Minibar72
Member #: 1655
I have a VW Vento radiator placed in MOT 977L . (dim:528x299x22mm.)
With an electric fan and electric pump it works perfectly!!
slater
Member #: 1291
Suffolk / Birmingham
I use a mk2 polo rad, possibly quite simlar
The mounting holes in my Miglia are 445mm apart so it looks like it may have had the Polo radiator in it.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWA:IT&ih=008
It's a very similar size to the rad in MOT so should do the business.
Prawn
Member #: 5232
basingstoke
bit of a bump here.
is it definately the smaller golf rads that the migs run?
I saw a load at castle combe a few weeks back, and was told by 2 guys tehy were running mk4 golf rads, which are a 650x415 core....
I've just ordered a mk4 golf rad and it's arrive, but it looks fecking HUGE!!!!
Does anyone have any idea of the dimension from the subframe to top of slam panel on the mini? I don't mind if it sticks proud a bit, but if it's way too big I'll have to rethink and get a mk3 gofl rad instead.....
