| Home > General Chat > Turbo Oil Feed? | |||||||
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
10th Nov, 2008 at 09:25:30am
I'm not sure how many other people have had this problem but its very annoying.
"Cars are a lifetime of pain" |
10th Nov, 2008 at 11:17:34am
I used a sandwich plate behind the oil filter housing on my build. It avoids all the messing with hydraulic fittings etc.
Gary's description is best |
10th Nov, 2008 at 11:58:25am
Ive found this aswell, mashed up an oil gauge feed pipe trying to do it up, thought it was just because the threads are slightly tapered, most of the thread doesnt actually go in to the t-piece, but ive yet to start it to see if it will leak. |
10th Nov, 2008 at 12:53:01pm
I also used a sandwich plate, loads better imo.
10th Nov, 2008 at 12:55:38pm
So all you need is a 1/8 BSP to 1/8 BSPT adaptor? Is this not an easy thing to source? On 17th Nov, 2014 Tom Fenton said:
10th Nov, 2008 at 03:08:30pm
I use a remote filter housing because my alternator sits low so i had more room for my intercooler! I suppose i could tap a hole in my blanking plate though,good idea, never thought of that! will that get a constent supply of oil, excuse my ignorance, i have no idea about the oil galleries. "Cars are a lifetime of pain" |
10th Nov, 2008 at 05:48:37pm
if you tap into the blankign plate there it will be before your filter stef
Edited by joeybaby83 on 10th Nov, 2008. "Turbo's make torque, and torque makes fun"
10th Nov, 2008 at 06:00:30pm
Beach grove engineering 01525 382968 Speak to Alan
Own the day
10th Nov, 2008 at 06:06:49pm
On 10th Nov, 2008 TurboDave said: But you can mate NPT AND BSPT did this on mine. No leaks all you need is the tap.
So all you need is a 1/8 BSP to 1/8 BSPT adaptor? Is this not an easy thing to source? Own the day
10th Nov, 2008 at 06:09:39pm
All the male male fittings above are 1/8 BSP parallel to a tapered body fitting. Edited by Mr Joshua on 10th Nov, 2008. Own the day
444 Posts Member #: 2885 Senior Member |
10th Nov, 2008 at 07:44:40pm
Could tap into the end of the banjo bolt? |
10th Nov, 2008 at 08:05:13pm
On 10th Nov, 2008 ministef1 said:
will that get a constent supply of oil, excuse my ignorance, i have no idea about the oil galleries. We used 2 oil pressure gaiuges on mine while cranking. There was only about 5% difference in the pressure reading at the sandwich plate and the oil pressure switch hole On 12th Nov, 2009 Paul S said:
10th Nov, 2008 at 09:46:32pm
an the guage on the sandwitch plate is out of cal my 5% :) On 17th Feb, 2009 Rob H said:
10th Nov, 2008 at 09:55:56pm
I love all these ideas but surely someone should just make something of the shelf? Why after 20 years of the metro turbo is there still noting of the shelf which is correct?????? its beyond me, but i thing i am going to tap into the blanking plate. cheers guys! once again i knew i'd get the right answer from TM!!! "Cars are a lifetime of pain" |
10th Nov, 2008 at 09:56:48pm
On 10th Nov, 2008 PaulH said:
an the guage on the sandwitch plate is out of cal my 5% :) So its a 10% reduction in pressure
10th Nov, 2008 at 09:59:34pm
so instead of 70-80 psi at the gauge it will be 60, i'm sure thats more than enough!!!!
10th Nov, 2008 at 10:01:47pm
an the guage on the sandwitch plate is out of cal my 5% :) So its a 10% reduction in pressure ![]() On 17th Feb, 2009 Rob H said:
10th Nov, 2008 at 10:03:07pm
so instead of 70-80 psi at the gauge it will be 60, i'm sure thats more than enough!!!! ah, I was only taking the piss out of Paul. We would need a more accurate way of measuring both pressures. It could be anywhere from 0 - 10% drop if the gauge is 5% off relative to the other gauge. Either way, I think its a neat solution and I'm sure it will work perfectly On 12th Nov, 2009 Paul S said:
