| Home > Help Needed / General Tech Chat > front ball joint help | |||||||
60 Posts Member #: 4055 Advanced Member teeside |
11th Nov, 2008 at 05:04:18pm
hi was wondering if anyone could explain to me about the front ball joints how tight i need them how many shims etc im new to mini,s and have only renewed rubber ones should they be really tight or have a slight play on the balls i have ordered 2 repair kits is this 1 repair kit each side top and bottom or is there 2 types and you get both but only use 1 hence do i need 4 repair kits any advice and tips greatly appreciated hopefully mini,s on the road tomorow please give me some advice thanks |
11th Nov, 2008 at 06:04:48pm
First of all one repair kit does a side of the car, so one kit does the upper and lower joint.
Edited by Tom Fenton on 11th Nov, 2008.
11th Nov, 2008 at 06:08:08pm
Exactly as above but leave the spring out of the bottom one while you are trying the different shims and only put it in after you have selected the right shims.
11th Nov, 2008 at 06:47:37pm
thanks for info much appreciated |
11th Nov, 2008 at 08:55:59pm
youtube.. already done like 3 full sets and im onto my 4th but all you need to know is here Yes i moved to the darkside |
12th Nov, 2008 at 09:43:41am
The pins should be hard to move by hand but should move ok with a small ring spanner on them if that makes sense. |
12th Nov, 2008 at 07:10:00pm
job done thanks brett for video made everything understandable thought it would be a nightmare getting them undone but turned out to be nice easy job thanks to all for help |
