| Home > Help Needed / General Tech Chat > who has an engine out of the mini with a pre-verto? Need a measurement! | |||||||
12th Nov, 2008 at 04:56:41pm
Awight everyone!
Edited by turbodave16v on 12th Nov, 2008. On 17th Nov, 2014 Tom Fenton said:
12th Nov, 2008 at 07:45:38pm
Hey thats my setup! I want royalties you bugger. I have a transfer housing i can measure for you tonight. And a spare wok, so i could just measure to the bearing?
12th Nov, 2008 at 07:52:40pm
I have an engine but not enough bits to make up a complete fywheel assy.
12th Nov, 2008 at 07:57:35pm
I have an engine on show buts it verto! Edited by MikeRace on 12th Nov, 2008. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
12th Nov, 2008 at 08:41:55pm
I could try to do this on Saturday as myself and Vegard will remove the engine from my car then. |
12th Nov, 2008 at 09:03:03pm
Hi Mike, Yes, I twocked your picture like a pikey with a hi-ab...
12th Nov, 2008 at 09:46:25pm
dave got one in the garage but your pic does seem to be correct as the arrows go off the screen... so I'm not sure what you want measured I run a supercharger and I don't care the TB is on the wrong side.
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
13th Nov, 2008 at 02:41:54am
will try and get a measurement tonight.
13th Nov, 2008 at 07:43:18am
On 12th Nov, 2008 miniminor63 said:
I could try to do this on Saturday as myself and Vegard will remove the engine from my car then. And on sunday I will try to have the freshly balanced flywheel stuff bolted on my 1100T. That means two different readings Davy! Export measurments! On 13th Jul, 2012 Ben H said:
13th Nov, 2008 at 07:44:38am
Davy? Davy crockett? |
13th Nov, 2008 at 03:20:19pm
I may be able to get it tomorrow. I'll post up if I get it On 12th Nov, 2009 Paul S said:
Gary's description is best |
20th Nov, 2008 at 01:52:41am
20th Nov, 2008 at 11:08:09am
20th Nov, 2008 at 11:10:03am
and you Vegard forced me to forget to take the measurement while we dismantled mine, so sorry Dave!
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
20th Nov, 2008 at 05:02:37pm
54mm, ill double cheak in the day light |
20th Nov, 2008 at 05:32:36pm
Cheers Vegard and Angus.
12th Jan, 2009 at 09:23:38pm
bit late but....
12th Jan, 2009 at 10:03:21pm
Well, I was working to 53 to 56mm tolerance range - maybe I'll up it a little more to 52.5 - 56.0mm
13th Jan, 2009 at 12:45:26am
I'll measure mine second week in Feb On 26th Oct, 2004 TurboDave16v said:
13th Jan, 2009 at 01:07:00pm
53.8 ish on a different engine i had out on the hols. i was just curious about this and wrote it down the last minute.
