Home > Help Needed / General Tech Chat > clutch probelms
Alex1340
Member #: 111
Loughborough
There are worries that my metro turbo verto clutch won't take the power that my 1380 supercharged engine will kick out. Looking for options to upgrade. I have heard that vmax can do modded verto clutch plates to give more clamping pressure. The the other option is to go pre verto what parts would I need to convert and ruff idea of cost?
Thanks
take a look at robert double spring verto mate. seems to have lasted on his as far as i know and i would have thought his is putting out more power than your expecting.
Ric
Member #: 36
Basingstoke
robert certainly seems to have cracked it with his set up. But it might be slightly easier and cheaper to go pre verto if you don't mind a little bit of peddle pressure.
There's tons of post on here about what you need. If memory serves correctly the parts you need to change are...
flywheel (make sure you get the correct ring gear for your starter)
clutch plate
back plate
diaphragm (at least an orange, I'd personally go straight for grey)
drive straps (if the flywheel doesn't come with them
clutch release bearing
plunger & arm
clutch slave cylinder
1 piece hose for the cylinder
If you ring any decent mini parts supplier (I always use min-its) and tell them what you are looking to do they will sort you out with all the parts.
Alex1340
Member #: 111
Loughborough
is there a thing on here about Robert clutch? Or has some one got dome details?
Here's the link:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10207
You need to go down a few pages before you get to the double spring version.
Alex1340
Member #: 111
Loughborough
right, i understand some of that. but very little in a how to kind of way...
