| Home > Help Needed / General Tech Chat > having trouble with maniflow | |||||||
7th Sep, 2004 at 09:47:37am
im having trouble with my maniflow large downpipe. Ive got it to fit on the manifold properly without knocking, but the link pipe is too small and i dont know how you deal with this ive had no experience of it, the last standard metro downpipe was perfect size for my playmini link pipe and backbox. I tried making the flanges bigger on the linkpipe to clamp round the downpipe, but it still managed to flal off. The downpipe is about 5mm wider than the link pipe, its as if i need a exhaust size convertor or something, but i might have made them up! Also, cant weld it because link pipe is stainless :( Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Sep, 2004 at 10:19:18am
basically the playmini system is too small. you need to sleeve the downpipe to get it to fit.
7th Sep, 2004 at 10:47:19am
Yeah agree with Iain, I have a maniflow downpipe and a playmini system, with the one I have, the exit of the downpipe is exactly the same size as the entry to the link pipe, hence it won't fit. When I have finally got the engine built and in the car I am going to get a mate to weld a sleeve over the playmini link pipe to accept the maniflow downpipe.
7th Sep, 2004 at 01:10:56pm
thats not good news, i have 3 days of it left on ebay and it needs to be ready. At least i dont have to do the twatting exhaust clamp again! im wondering, what would hapen if i cut flanges into the maniflow donwpipe end, will it then clamp onto the link pipe if i tighten it up enough? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Sep, 2004 at 01:36:18pm
I severely doubt it, it might stay together for a bit if you are lucky but it certainly won't seal very well and so will blow like monica lewinsky.
7th Sep, 2004 at 03:29:36pm
anyone know the diameter of the maniflow downpipe? Need to know to tell people Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Sep, 2004 at 04:03:32pm
A full maniflow single box system is about £90 with side exit stainless pipe.
47 Posts Member #: 329 Member |
7th Sep, 2004 at 04:20:11pm
Feebleuk
969 Posts Member #: 47 Post Whore Not very sunny swanage |
7th Sep, 2004 at 04:39:51pm
mild steel to stainless with mig? not with decent weld quality, now tig would be a different story. And on the 7th day........... God created turbochargers! |
7th Sep, 2004 at 05:01:31pm
Have done it a thousand times with no problems at all.weld might suffer accelerated corrosion and breakdown at the edge of the weld due to electrlytic corrosion but wont be anything significant.If you want to do it on a regular basis use a grade 347 stainless wire as its main purpose is for welding ferrous and non ferrous metals. |
![]() 1014 Posts Member #: 238 Post Whore essex |
7th Sep, 2004 at 07:30:10pm
i had this problem recently!
