Home > 998cc > exhaust manifold sizing
Advantage
Member #: 1450
Near Paris - France
I am considering building my own manifold for my standard 998 12G295 head turbo engine.
Reason is I want the turbo on the clutch.
My favorite yellow book (the one with very few phone numbers) states I need 1"1/4 ID for outers and 1"3/8 D on centre branch.
That is for N/A engines with a power expectancy of 70 to 110 HP.
But exhaust valve is 1" wich is 64 % of the exhaust area, assuming 100% efficiency of the valve.
I am trying to avoid lag without compromising maximum bananas
So what size would best apply in your opinion ?
Thanks in advance
Rusty by nature
alpa
Member #: 2093
Grenoble, France
I think the optimal sections are the same for NA and FI engines because the expelled volume is still the same, it's a matter of pressure.
Ben H
Member #: 184
Melton Mowbray, Pie Country
So long as they are as big or bigger than the exhaust ports where the manifold meets head I would say it will be fine. I am sure there is some maths out there that can work it out, but remember that the turbo is a masive restriction.
http://www.twin-turbo.co.uk
This was discussed a couple of weeks ago.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=253314
The sizing in the Vizard book is totaly irrelevant for a turbo application. Keep the branches small.
Advantage
Member #: 1450
Near Paris - France
I thougt so !
Thanks Paul
So it is small before turbine and big afterwards.
I'll go for small bore size before turbine
Rusty by nature
