Home > For Sale > Bits for sale
Richie
Member #: 628
Pics to follow when i get the chance
set of four mint halogen lamps on brackets as per pics below £80
1275 A series thick wall blocks x 2 complete with mains £40 each (*Yes*SOLD TO Miniminor63*Yes* )
1275 A+ block with mains and a set of rods / pistons £45
1275 GT crankshaft 12G1505 in good condition £40
Mercedes intercooler (sightly larger than the RS turbo ones) £15
1100 rads with fan shrouds x 2 £15 each
galvanised Metro petrol tank new £35 (*Yes*SOLD TO BENROSS*Yes* )
pair of doors frames ok but skins are nailled £50 the pair
mk3 bootlids x 2 £10 each
rear perspex screen and seal for metro £10
metro door handles £5 each
1275 cooper S rods with cossworth pistons x 3 £75
balanced set of rods (i think they are sprite rods 12G1507's) £75
998cc cylinder head £35
box of assorted headlamps and tail lights £25
petrol tanks x 2 standard size un modded complete with senders £10 each
rear S type brake drums with spacers £10 the pair
assorted glass (no fronts or rear screens though) £5 per peice
set of 10 x 5j wellers £45 3 with tyres 1 without tyres are in good nick though.
set of original 1964 10 x 4.5j steel wheels in what i can only describe as ivory paint. complete with original tyres all good nick £75
end casings both A and A+ mix (not the bell housing just the transfer case itself good nick £10 each
izuzu trooper 3.1 TD cylinder head and manifolds £40
set of izuzu modular wheels for offroading good nick £40 the set
set of hellacle cut metro turbo gears including diff which is builtup with bearings and outputs gears are all in good order £45
more to come as i find bits and bobs.
Richie. everything negotiable within reason
Edited by Richie on 2nd Dec, 2008.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
Richie
Member #: 628
also have a roundnose plastic front end but it has been rally crossed so will check it, £15 ------if its shagged i will update the thread to that effect.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
stefaz
Member #: 1656
stoke-on-trent
could do with a transfer casing with a breather on it if you have one please rich?
Richie
Member #: 628
yes should not be a problem, I am about to go to work so it will be tomorrow buddy but like i say that should not be a problem at all.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Si P
Member #: 912
North Yorkshire
Hi there
I'm after a A+ transfer case to. if you happen to have one.
Si p
philc
Member #: 1346
bromsgrove
why so far away, I would have had the 1275 +a block *crying*
Same for me. I'd have the A block if it wasn't for you being in a different country :)
Richie
Member #: 628
Vegard i think miniminor has beat you to it, he may be popping over My end at some point but i got to check some bits on the block for him first.
Sip i will check and see how many are A and how many are A+ fella i will let you know.
Vegard did you speak with your mate ?
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Si P
Member #: 912
North Yorkshire
Cheers Richie
The one that came on my turbo lump looks like it has been attack by a hammer wheeling retard...!
So, a fresh one is required.
Si p
Is the a+ block n bits still up for grabs
Rick
Vegard, how much do you want to pay fro Aseries blocks,
sorry about the hyjack richie
Richie
Member #: 628
Sip has first dibs on the A+ block
and minor has first dibs on the A blocks
also found a set of nice spot lamps on 2 up 2 down brackets which i have added a bit onto (but could be removed) to tilt the lamps
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
richie will take the galved metro tank buddy.
please PM me i will phone you
Richie
Member #: 628
no problems matey, i still need to bring that engine down to you and the cooler i have got for ya too
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
I'll have the block Andrè doesn't want. He can pick it up for me :)
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I have never said I do not want a block!
Richie
Member #: 628
hahahahahaha nice try V loving the deviousness, why dont you both come over, buy me mini and take everything out of the garage mini related !!!! I may be able to get a trailler for it to take it away on lads
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Richie
Member #: 628
a few updates
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
