| Home > Help Needed / General Tech Chat > Another gearbox question (I guess that means I've started the gearbox rebuild then) | |||||||
28th Nov, 2008 at 11:05:07pm
When taking the 3rd motion shaft out of the gearbox I let the sycro hubs get a bit loose so of course the balls and detent springs wizzed past my ear. So putting it all back together again is going ok but I don't know which way the inner parts of the syncros orientate. Does the raised but on the 1st/2nd sync go towards 1st or toward second gear (see pic) and same with the 3rd/4th sync?
Edited by Jay#2 on 28th Nov, 2008. On 7th Nov, 2008 Nic said:
28th Nov, 2008 at 11:27:21pm
The raised centre goes on the same side as the "biggest" shiny part of the syncro hub. Did that make sense? :)
28th Nov, 2008 at 11:40:25pm
So does the raised bit go to the same side as the bits circled in green:
29th Nov, 2008 at 09:42:25am
NO. The side of the biggest shiny bit, not the raised bit On 13th Jul, 2012 Ben H said:
29th Nov, 2008 at 11:42:29am
Ahhhhh I see! Thanks my fluent english speaking all mini knowing Norwegian friend! Back to the garage then! Too much coffee! Zzzzzzzzzip! On 7th Nov, 2008 Nic said:
29th Nov, 2008 at 03:44:08pm
Getting there:
