Home > Help Needed / General Tech Chat > t2 oil feed
turbominij
Member #: 2104
Essex - UK
I have a mirage manifold using a t2 from a Renault 5 turbo i am using a oil feed that mirage supplied works a treat, however every time i have taken this off i have always had problems (more of a fiddle) getting it back on and tightening it up is this just me or is there a way or tool that makes this easier that i have over looked. i am doing it with the while turbo assembly on the car
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
Which end are you removing.
I always leave the turbo attached and take it off at the block.
turbominij
Member #: 2104
Essex - UK
i had to remove the turbo end because of swapping turbos unfortunatly
is there a nack to doing that end up
Mirage
Member #: 119
The fittings are unf so you should be using AF spanners.
If its the usual 7/16 adaptor your having trouble with check the seat in the turbo body is clean as the fitting has the proper seat on it and seals against the bottom of the hole / base of fitting.
All the other fittings seal on a taper so make sure all faces are clean.
Hope this helps
there are also 2 different sizes of fitting on a T2 IIRC...
TD knows more than me as i'm sure it was him who mentioned it.
turbominij
Member #: 2104
Essex - UK
the ones i have do up and seal i ahve had them done up before. it is just almost inpossible to get to and do up tight because of other bits of the turbo being in the way is there a tool or a nak to it
Mirage
Member #: 119
Oil feed threads
Fittings seal in a seat in the base of hole in the turbo body.
7/16" unf 24tpi (normal unf is 20tpi)
1/2" unf 24tpi (again normally 20tpi)
you could try stubby spanners or
http://www.diytools.co.uk/diy/Main/sp-69-7...ategoryID1=7139
or try making your own tool by heating and bending a spanner
Edited by Mirage on 2nd Dec, 2008.
turbominij
Member #: 2104
Essex - UK
thank you for ur tips those crow spanners looke usefull. (cant beleave i never thought of making something to do the job )
Nick
Member #: 154
Midlands
on my turbo i have to rotate the housings to get a spanner on my oil feed banjo bolt.
and to throw an oddball in there my T2/T25/GT something or other is an M12 thread on the oil feed.
turbominij
Member #: 2104
Essex - UK
u would have thougth they could have made it easy and just made everything the same
but no i guess all these companies know better
o well life goes on
