| Home > Help Needed / General Tech Chat > 16v Bonnet Fitment | |||||||
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
13th Dec, 2008 at 04:47:08pm
the pissed up clown stood back up, did a twirl and left bollock naked, |
13th Dec, 2008 at 05:06:13pm
i think once you have put some bonnet pins in this may sort it out |
13th Dec, 2008 at 05:12:57pm
It does the passenger side, however the middle still protudes. On 15th Jul, 2009 fastcarl said:
13th Dec, 2008 at 08:12:10pm
Wheres the bonnet from?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
13th Dec, 2008 at 08:45:26pm
well, i brought it off a mate, but im 99% sure he said he brought it from tdk. On 15th Jul, 2009 fastcarl said:
13th Dec, 2008 at 08:48:50pm
Mines a TDK but i specified it would be mk1. If your that bothered Dave will make one a tad thicker for you.
13th Dec, 2008 at 08:50:20pm
does that mean he'll make it with out the lip on then? On 15th Jul, 2009 fastcarl said:
13th Dec, 2008 at 08:55:13pm
Yeah, just ask him. Or I can if you want.
13th Dec, 2008 at 08:59:57pm
would he also be able to make the bonnet with hinge brackets so i can sill just lift the bonnet up?
13th Dec, 2008 at 09:04:16pm
You would have to do that ureself mate.
13th Dec, 2008 at 09:36:33pm
Fair enough.
14th Dec, 2008 at 08:46:54am
On 13th Dec, 2008 MikeRace said:
You would have to do that ureself mate. If i were needing the hinges i would get some angle iron and get some fibreglass filler/sheets from my local motor factor and glue that on. If you use fibreglass to stick some brackets on the heat from cureing could distort the skin. I had this problem once with a GRP bonnet. Id use something like Sikaflex Paul I seriously doubt it! |
14th Dec, 2008 at 11:25:20am
On 13th Dec, 2008 mini_surfari said:
well, i brought it off a mate, but im 99% sure he said he brought it from tdk. So where did you mate buy it? On 13th Jul, 2012 Ben H said:
14th Dec, 2008 at 11:29:29am
BFH!
14th Dec, 2008 at 02:09:50pm
well, i brought it off a mate, but im 99% sure he said he brought it from tdk. So where did you mate buy it? went and seen him today, and he said tdk, so im guessing i may have made a slightly shitty job of cutting the lip off. So im going to have a play, and reshape the edge slightly. On 15th Jul, 2009 fastcarl said:
14th Dec, 2008 at 02:10:28pm
14th Dec, 2008 at 06:58:31pm
well, i brought it off a mate, but im 99% sure he said he brought it from tdk. So where did you mate buy it? went and seen him today, and he said tdk, so im guessing i may have made a slightly shitty job of cutting the lip off. So im going to have a play, and reshape the edge slightly. I guess you're right. If he brought it from TDK, I guess he bought it there as well. On 13th Jul, 2012 Ben H said:
14th Dec, 2008 at 07:03:48pm
i'm with Vegard on that one On 26th Oct, 2004 TurboDave16v said:
14th Dec, 2008 at 07:24:57pm
Well after 5 hours of fettling, cutting, fibreglassing, fillering, and sanding, it fits perfect. So im happy with it.
14th Dec, 2008 at 11:38:36pm
