Home > Technical Chat > tran x, quaife and cross pin???
DD_Racing
Member #: 3013
Epsom Surrey
does any one know of tran x doing a plate type lsd that will fit pot joints and the original crownwheel???
also id love to hear all of your experiences with all the different types of diffs
as id love a tran x but if i gota change to hardy spicer shafts and change the crownwheel i doubt id be bothered
so just looking for options at the moment!!!
i did a group buy for quafies last year and thinking of doing another as i want one this winter
worked out at £490 delivered which wasnt bad
DD_Racing
Member #: 3013
Epsom Surrey
were they the pot joint type where you can use a original crownwheel???
Yes, but they are not a plate diff they are the ATB torque bias type.
When you thinking iain?
put me down for one .
Rick
And me.
Ben H
Member #: 184
Melton Mowbray, Pie Country
When you buy the diff you also need to buy the output shafts, these link the shaft to your chosen joint, pot or hardy. Unfortunately you will have to buy a new crown wheel and pinion as they don't fit.
http://www.twin-turbo.co.uk
uhmmm depending when i might be on for the group buy aswell.
Star Mag
Member #: 375
Leicestershire
I will be up for a group buy as well as im thinking of getting one. I think on the later style of diff you dont need to get output shafts to fit the pot joint as they are built into the diff??
DD_Racing
Member #: 3013
Epsom Surrey
ahhh right has anyone been on the swiftune site????
they sell atb diffs on there that keep the original crownwheel and use pot joints!!!!
570 quid though *indifferent*
they are the same as the ones we did a group buy for last year.
any other lsd will need the crown wheel machined, normally the highest ratio you can do this to is 3.44, somone on here machined out a 3.1 IIRC but i belive it broke after a bit.
DD_Racing
Member #: 3013
Epsom Surrey
ahhh right well i got a 2.9 on mine n dont really wna go any lower
what do most people run because some one said to me that 2.9 is crap but i prefer it purely because i dont wana be reving the ass off it on the motorways n a roads...lol
it eats the gearing anyway lol
hammered it down the a3 got to about 110 before the head gasket came out the side of the block haha
on turbo's the 3.1 is common, the 2.9 is a good choice if you go on the motorway a fair bit.
the 2.9 is pretty crap in a n/a but with the extra torque from the turbo its much better.
3.44 is about as low as you want to go for a road car.
DD_Racing
Member #: 3013
Epsom Surrey
yeah i mean im doing about 3 grand at 64mph with the 2.9
ill just see what its like when it take it up the pod
see what rpm im doing as i cross the line
pm me your email addr,
i have a handy gear calc program.
DD_Racing
Member #: 3013
Epsom Surrey
ahh wicked i could really use that but i dont know the ratios of my box apart from the differential
yup, the group buy is from swiftune and i will do it jan/feb at a guess.
you can use normal crownwheels and it is set up to do pot joints so a bargain really.
£80 isnt a bad saving! ?BUT i havent had a price off them yet, that was last summers price but hopefully it was something like. worked out 15% off i think then obviously had them to post out afterwards so that was about £10
DD_Racing
Member #: 3013
Epsom Surrey
well ill be interested in that if someone does a group buy
Tweaked
Member #: 2873
i'm in for a group buy
If you are using it on the road moastly, then you don't want a plate diff anyway. even the one with the least locking will be too much IMO. Also plate diffs wear. ATBs are far better for road use.
philc
Member #: 1346
bromsgrove
i have an atb works a treat well recommended
TurboHarry
Member #: 115
Austria, near Vienna
Hi Mini 13,
I did the 3,1 FD for the Quaife LSD - it is still ok, a lot better than the soft laygears that don't survive my motors too long.....
http://www.minifreunde.at/harry/links/differential.htm
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
