| Home > Technical Chat > lighten timing gear further? | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
14th Dec, 2008 at 05:22:11pm
forgetting vernier and sticking with a normal duplex kit, could it be lightened any further than the lightened version you can buy?
Edited by Simon on 14th Dec, 2008. |
14th Dec, 2008 at 05:31:20pm
You could possibly get away with joining every 2 holes together to make 4 slots but why not buy the Swifty alloy centre set or the MED all alloy set?
Edited by paul wiginton on 14th Dec, 2008. I seriously doubt it! |
14th Dec, 2008 at 05:40:29pm
On 14th Dec, 2008 paul wiginton said:
You could possibly get away with joining every 2 holes together to make 4 slots but why not buy the Swifty alloy centre set or the MED all alloy set? Paul its just an idea as i ulready have the normal duplex kit, so to lighten the one i have (save pennies) or just buy a new set |
14th Dec, 2008 at 05:48:25pm
The Swifty one is quite cheap, not sure about the MED one though
444 Posts Member #: 2885 Senior Member |
14th Dec, 2008 at 09:34:38pm
Arent they made from fatally weak sintered steel and neeed as much meat as poss.? |
14th Dec, 2008 at 11:43:38pm
So what do you achieve by lightening this a further 29 grammes? On 13th Jul, 2012 Ben H said:
14th Dec, 2008 at 11:52:32pm
29 grams less wieght! |
261 Posts Member #: 713 Senior Member Western Australia |
15th Dec, 2008 at 02:21:46am
Number 3 is a definate NO! Just asking for breakage.
On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
15th Dec, 2008 at 06:55:02am
Put a chamfer on the sharp corner near the edge, thats what i do when im lightening the standard ones. (attulay thats what he said^^)
20th Dec, 2008 at 03:20:57pm
changing the subject slightly, i've been looking at the MED all alloy set, and been offered the minispeed vernier belt drive kit for the same price, so belt or chain? (chain noise is not an issue, changing belts not an issue either) |
21st Dec, 2008 at 09:29:38am
i would stick with chain, to manu issues with adverse oil leaks from the belt kits about. always looking for them bigger bunches of bannanas |
