Home > Help Needed / General Tech Chat > Engine breathing
Star Mag
Member #: 375
Leicestershire
If i was to change my timing gear setup to a belt drive setup would the engines breathing system have to be improved as i would be loosing a breather? I already have a breather off the transmission case and a breather from the rocker cover too a catch tank. This would be on a fresh rebuild. Any help appreciated Ron
Would of thought that would manage perfectly well.
My old mig engine had one from the transmission case to the rocker cover, then out the rocker cover. made it neat.
I stuck the timing cover one in as it was on there, no other reason. just tee-d it in. although i may well get rid of it this winter to tidy it up and loose weight *happy*
get one of these bargains
http://cgi.ebay.co.uk/Mini-miglia-race-car...A1%7C240%3A1318
Do you really think that is a bargain, or are you being sarcastic?
are you?
Star Mag
Member #: 375
Leicestershire
The pictures wont come up for me with that link joey, But from what i can gather it's rather overpriced *happy* I reackon my current setup cost about £10! I didnt think it would effect the engine greatly but just wanted to see what other peoples opinions were!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Blimey...how much!
Done a rocker box for a friend last week, same as the meccy setup.
On 19th Jan, 2010 wil_h said:
Star Mag
Member #: 375
Leicestershire
Very bling Jason! Im going to go back to a alloy rocker cover in the future!
Mine is EXACTLY the same as in the ebay pic *smiley*
Slight larger with no canister at the flywheel end and in and out the rocker cover. i guess in 1" pipe
getting the hang of the tig then jason!
tadge44
Member #: 2500
Buckinghamshire
I guess with the mini engine breathers are a little less important than the inline A series where we have a problem with oil leaking past the rear main to the garage floor,especially if the breathers are in any way inadequate. I have breathers from the crankcase, the timing cover and the rocker cover and its still only just about good enough.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Alas...I would love to take credit for it, but mate at work done it for some beer money. I just gave it a quick polish.
I'm not consistant enough to do other peoples. :(
Edit..I give you the ally tube offcut back from the catch tank over Christmas Joe.
Edited by Jason G on 18th Dec, 2008.
