| Home > General Chat > The importance of brace bars | |||||||
27th Dec, 2008 at 04:54:43pm
http://uk.youtube.com/watch?v=8rqQNaRrEFc&feature=related On 13th Jul, 2012 Ben H said:
27th Dec, 2008 at 06:41:32pm
I've never had any problems like that on mine, maybe they measure the power differently over there? Best 1/4 mile 13.2 seconds @116 mph
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
27th Dec, 2008 at 06:41:46pm
Thats pretty interesting!
This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
27th Dec, 2008 at 08:32:43pm
probably do more good to stop the floor flexing. The brace bars dont really offer much triangulation if you think about it they more or less fit to the same area as the top mounts so it all pivots around that point. Edited by slater on 27th Dec, 2008. |
27th Dec, 2008 at 09:00:13pm
yeah but surely because they are fixing the front of the frame to the bulkhead, this will majorly reduce/stop the movement? |
27th Dec, 2008 at 09:04:10pm
when was he last time you saw a clubby with Mk1 door hinges?
27th Dec, 2008 at 09:06:26pm
aussie clubman?? Edited by James_H on 27th Dec, 2008. |
27th Dec, 2008 at 09:10:30pm
On 27th Dec, 2008 Sprocket said:
when was he last time you saw a clubby with Mk1 door hinges? I Recon that is a Mk3 rubber mounted subframe. James is learning! keep up sprock. Rick |
27th Dec, 2008 at 09:31:07pm
valid point but I still recon the only way you get that much movement is with a rubber mount frame On 26th Oct, 2004 TurboDave16v said:
27th Dec, 2008 at 10:39:05pm
Would i not have a problem case my frame is mounted solid in places? maybe your on to some thing. Best 1/4 mile 13.2 seconds @116 mph
28th Dec, 2008 at 12:39:42am
On 27th Dec, 2008 Miniwilliams said:
Would i not have a problem case my frame is mounted solid in places? maybe your on to some thing. i say rubber tear drops also, |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
28th Dec, 2008 at 01:54:11am
nope it is an aus clubby so it will have a solid mounted mk1 style subframe. I know as i have one. |
784 Posts Member #: 912 Post Whore North Yorkshire |
28th Dec, 2008 at 02:29:54am
Something wrong there..?
I drill holes in everything..! |
28th Dec, 2008 at 11:53:05am
my car did the same on the rollers.. if any of you are familiar with most frames for alien engines you will know that the main force from the tie rods is transmitted to the car via 2 bars which run (and usually bend as a result) under the sump and gearbox. these are under a tremendous amount of load under acceleration and breaking, in the first incarnation of my frame, i found some fatigue fractures in one of my lower bars, right at the centre of the angle cut where it bent up after coming under the sump. indicating it had been bending. 2nd incarnation of the frame i heavily gusseted and braced the bends in the lower rails, and suffered no fractures since. however, when the car was on the rollers you could see the same kind of flex. the tie-rods were pushing forwards and lifting the nose of the frame up. 3rd incarnation of the frame and i have added a second set of bars from the tie rods straight back to the floor pan with no bends, whilst keeping the original bars, for a belt and braces approach. less bending and car pulls straighter under throttle :) .. isn't there a video of MOT's front end doing the same thing on the rollers?? the same video where there was a wee fire? Edited by evolotion on 28th Dec, 2008. turbo 16v k-series 11.9@118.9 :)
28th Dec, 2008 at 12:09:25pm
without seeing pics of the engine bay we dont know what engine/subby could be a non a series. no longer a series, but still 1.3 turbo.
28th Dec, 2008 at 12:21:02pm
sure i seen a link to that video before on another site, and it said it was a 4efte, could be wrong though, but would make sence as there popular in aus! where they have tehre externall hinged sliding windowd clubbys. turbo 16v k-series 11.9@118.9 :)
28th Dec, 2008 at 12:22:09pm
On 28th Dec, 2008 Carl said:
without seeing pics of the engine bay we dont know what engine/subby could be a non a series. Toyota Starlet says on the vid/site? On 5th Sep, 2011 Vegard said:
28th Dec, 2008 at 12:59:44pm
its a 4efte turbo from a toyota starlet,with home made subframe based on a mini subby, all signed off and certified by an engineer as all engine conversions have to be in Aus. Edited by miniboo on 28th Dec, 2008. |
28th Dec, 2008 at 01:10:15pm
hmmmm,
28th Dec, 2008 at 01:13:08pm
this doesnt just happen to home brew frames! solid mount a late frame and it just bolts to the flat heelboard.(the frame in the vid obviously bolts to a different place, i was just suggesting a reason for its flexing) iv suffered signs of fractures here(on the heelboard) on a standard 998 mini with a solid frame like i say the video of MOT had the front end lifting up under throttle.. Edited by evolotion on 28th Dec, 2008. turbo 16v k-series 11.9@118.9 :)
28th Dec, 2008 at 01:17:04pm
i'll stick with my mk1 subby then! On 28th Aug, 2011 Kean said:
28th Dec, 2008 at 01:46:19pm
The rear mounting points on the early (non-rubber) are certainly at a much stronger point (re-inforced angle change between healboard and floor).
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
29th Dec, 2008 at 05:27:13am
Hi all, I know this car pretty well and it has been sold recently, it actually made 201hp at the wheels just before he sold it.
179hp on 12psi 1293cc of pure A series
29th Dec, 2008 at 01:24:36pm
Well,
29th Dec, 2008 at 08:34:39pm
i think the movement is more to do with the fact that the engine is solid mounted than the subby design.
