| Home > General Chat > Any electricians on here? | |||||||
28th Dec, 2008 at 07:57:26am
Thinking about fitting an electric shower in my house, theres nothing there at the moment, so would need to run a cable. However the bathroom and fusebox are pretty much at opposite ends of the house, so what is an acceptable way of running the cable? I was thinking, from shower, bury it in wall up into loft, then run it along in the loft to other side, then two options, 1) try to run it down a pipe void to the upstairs, then run it under the floor and thru the ceiling to the fuseboard, or 2) try to feed it down the cavity to the fuseboard.
28th Dec, 2008 at 08:57:55am
you could link it off another feed into a fused switch, just remeber a shower uses a hugh amount of power therefore you will need a thicker cable feed.
28th Dec, 2008 at 10:12:43am
dont worry about part P, you installed it years ago when you got the house right |
28th Dec, 2008 at 10:26:25am
On 28th Dec, 2008 iain said:
dont worry about part P, you installed it years ago when you got the house right ![]() If you do (and I do....), make sure you source the old colour cable, not new harmonised. I bought loads before the Regs came in to future-proof myself but it is still available on eBay and even from some electrical wholesalers. Otherwise it's a dead giveaway to insurance assessors, surveyors etc. However, if you want to do it "by the book", it's also worth searching the web site of your local authority as they all seem to have different interpretations of exactly what is required by App "P". Schrödinger's cat - so which one am I ??? |
28th Dec, 2008 at 10:48:09am
Sounds like old style cable is the way to go then, I've done a bit of net reading and it seems 10mm is the stuff I need, will have to try and find somewhere that has some in the old colours then.
18 Posts Member #: 3816 Member leeds west yorkshire |
28th Dec, 2008 at 11:04:16am
hi tom i know a few sparky's in rotherham could give you a few numbers if needed |
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
28th Dec, 2008 at 11:13:27am
I fitted my shower, its not hard to do you just need a spair breaker in your consumer unit and goo/ correct wattage cable for the appliance a switch out side the bathroom is good and a valve on the water inlet so you can turn the water off should you need to.
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
28th Dec, 2008 at 12:03:17pm
Electric shower?? internationally known as "big" swede |
28th Dec, 2008 at 12:23:10pm
you dont have to use the old type cable as the regs changed before the cable colours did, however there is only a small change over period so the old colours would be best |
28th Dec, 2008 at 04:00:59pm
I would consider a GFI as well, Its wise when electicity is anywhere near water. A GFI is a device that looks at the current and will trip the cicuit if it sees any imbalance between the current going in and the current returning, i.e if any of it is leaking through you!!
41 Posts Member #: 2397 Member Plymouth |
28th Dec, 2008 at 04:18:52pm
I am a sparky by trade but no longer do it for a living, however, I do try to keep up with the regulations for my own benefit.
Edited by mlarj on 28th Dec, 2008. |
28th Dec, 2008 at 05:51:17pm
i agree with mlarj i binned my electric shower for a mira combi, the electric ones died at least once a year usually just out of the 12 months Crystal Sound Audio said:
29th Dec, 2008 at 05:14:13am
Got to agree, a combi, is the way to go.
29th Dec, 2008 at 10:04:30am
Well I had a new boiler 2 yrs ago and its not a combi, so its a seperate shower for me, I did think about just a booster pump but it would mean serious bathroom bashing, whereas a electric shower isn't too much bashing to fit.
29th Dec, 2008 at 10:13:37am
The life of electric showers is down primarily to your water quality, it's as simple as that. If you are in a soft water area (or use a water softener) they should have a reasonable life. If you have hard water, the heating element will get plated with limescale very quickly and because their output is so high (3-4 times a kettle element), once the limescale is thick enough, they will overheat and fail. Schrödinger's cat - so which one am I ??? |
29th Dec, 2008 at 12:28:32pm
when at uni, in 1 year alone we went through 3 showers, our landlady wasnt pleased, but they just cruded up within months, those were the £100 mira ones "Turbo's make torque, and torque makes fun"
![]() 2102 Posts Member #: 432 Post Whore Swindon |
29th Dec, 2008 at 04:20:40pm
10mm cable off a 30 amp breaker, then just take the easiest root possible to the shower as 10mm is a bitch to work with.
103 Posts Member #: 2314 Advanced Member cumbria |
30th Dec, 2008 at 02:10:06am
Yeah u can just get away with 6mm with some showers but 10mm is the way to go. If i was u i wud fit a 30ma RCD aswell. This basicly is additional protection for electrical safety. They disconnect the supply much quicker than a fuse or mcb in the event of a fault to earth. I would always fit 1 just to make the install that much safer. |
3rd Jan, 2009 at 08:42:20pm
I looked into the cost, and it was hundreds of pounds to the council to approve and inspect your installation. Hardly worth legitimately doing it yourself unless it is a big job.
On 28th Dec, 2008 mlarj said:
There is nothing wrong with doing your electrics yourself, you just need to notify the council - at a cost no doubt, or get a qualified electrician to certify your work afterwards. (or just keep quiet as people suggest ) |
1391 Posts Member #: 1686 Post Whore Oxford |
3rd Jan, 2009 at 08:57:25pm
Also realisticly it needs to be in one run, as awkard as that is! On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
- no electrics to worry about so no part P
