| Home > Help Needed / General Tech Chat > bulkhead box q's | |||||||
969 Posts Member #: 47 Post Whore Not very sunny swanage |
16th Sep, 2004 at 07:58:15pm
im perfectly capable of using the search button, so no smart comments please.... And on the 7th day........... God created turbochargers! |
16th Sep, 2004 at 08:25:38pm
I didnt do that no...
AlexF |
16th Sep, 2004 at 08:44:28pm
Bolt the subframe to the car??
16th Sep, 2004 at 09:34:45pm
Nope i havent bothered. know exactly what you mean though, basically rigidly fixing the back of the subframe to the toe-board.
![]() 1014 Posts Member #: 238 Post Whore essex |
16th Sep, 2004 at 11:38:47pm
i bolted my subframe to the car; got a flat piece of stainless steel and cut it to the length of the flat part of the subby then bolted it to the toeboard in three places. my subby is fully solid mounted also and bulkhead box is full seam welded. didnt bother with the triangular pieces though. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
17th Sep, 2004 at 02:24:03am
remember to seam weld the box itself before fitting :) turbo 16v k-series 11.9@118.9 :)
17th Sep, 2004 at 10:02:30am
My subframe is stock and bolted in the original mounting points only. I wouldn't bother with the 'belt and braces' approch personally... On 17th Nov, 2014 Tom Fenton said:
421 Posts Member #: 245 Senior Member |
17th Sep, 2004 at 10:06:20am
as long as your welding is done well,no probs. |
17th Sep, 2004 at 10:12:13am
I have my front subframe solid mounted, seam welded the bulkhead box in, and also have bolted the front subframe through the shell with a spacer bar between the subframe and bodyshell, and also some large plates inside the car to spread the load.
Edited by Tom Fenton on 17th Sep, 2004.
17th Sep, 2004 at 12:32:38pm
cheers guys, i figure if you lot havent done it and got away with it, then i wont bother. i may well see if i can dig out some flat bar and bolt it up, but as for the welding......
![]() 198 Posts Member #: 345 Advanced Member Guildford Surrey |
20th Sep, 2004 at 07:45:02pm
The very first car we converted we used an alloy strip i think 1" x 3/4" by 10" long and this was used as a subframe/bulkhead brace but found it not necessary.
