Home > Help Needed / General Tech Chat > OT / BMW E36 Help needed
Ollie
Member #: 1380
Hi guys, just after a bit of advice as i'm a little lost and don't know what step to take next.
My car is an e36 320 with the M50 engine. Recently I noticed that from low revs with full throttle it wasn't pulling very well and not all that responsive.
Lived with it for a short while and only drove lightly using half throttle. But the occasional full throttle (still not much response) started to give off a horrid egg smell (cat i'm guessing)
So had a diagnositc on it, and got a few codes thrown back. The cam sensor, and the o2 sensor. I was advised to only replace the cam sensor as this being knackered was probably throwing the o2 sensor readings out.
I have replaced the cam sensor today, and taken it for a longish drive but still don't really notice any change. Arrived home and could smell the Cat giving off the horrid egg smell again.
Could me driving with a knackered cam sensor have caused the o2 reading to bugger up that much that it allowed the cat to overheat? so now my cat needs replacing? or is it possible that alongside the cam sensor, the o2 sensor needs replacing?
Sorry for the long write up :$ Any advice much appreciated
Ollie
The problem with diagnostics is there taken as gospel, although its showing a fault with the lambda the MAF the cat or something as daft as an air leak could cause it to show up as a lambda
personally i would look at changing the lambda with an OEM replacment rather than universal then go from there
well ollie and i changed the cam angle sensor as there was a fault with it.(quite common it seems). just needs the old codes removed i think then jobs a gooden :)
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I would imagine that your car is still running rich due to an O2 sensor fault. When O2 sensors go cars can run mental rich like 5%ish. If this happened to you it would have wanked your cat fairly quickly which is the reason for the smell. Check what the O2 is doing with a multimeter and get it on a gas analyser. You could then determine if the O2 sensor is ok or not
On 30th Apr, 2010 Rod S said:
Gary's description is best
uhmmmm,,the eggy smell would indicate that your cat is still operating.
basically:
Remove the codes.
Try it.
code read it again, if O2 sensor is back again, change it and get the codes taken out.
try it.
also check for any blows in the exhaust, or air leaks between the MAF/AFM and the throttle body.
I'd agree with this.
GaryOS
Member #: 2810
Dublin, Ireland
In my experience, cats really only smell when they are getting the shit roasted out of them though
Scruffy
Member #: 328
Seaford Rise, South Australia
Superb terminology lol :)
Edited by Scruffy on 2nd Jan, 2009.
On 5th Sep, 2011 Vegard said:
call the rspca!
On 2nd Jan, 2009 Ollie said:
H
Ollie
EErmm.... Reality check... This is the most gutless engine in the entire world. It NEEDS 5000rpm to even get moving....
Ollie
Member #: 1380
Thanks for all the decent and helpful replies (all of the above minus Vegards)
I will report back after I have changed the o2 sensor and had the fault codes removed etc :)
Thanks again
nutter driver
Member #: 47
Not very sunny swanage
i had a similar problem a couple of years ago (on a different car mind, but still....) after checking everything else it turned out to be one of exhaust boxes had collapsed internally and was massively restricting flow. prob not, but might be worth a quick check, tis free at least!!
Thanks again
Sorry, but seriously, the M50B20 is the worst engine in can think of when it comes to mid-range torque.
PaulH
Member #: 2340
Dublin Ireland
IMHO the cat is dying test the o2 sensor if you have a bar graph facility on your multi meter use that if it is working right it should be scanning between 0.0V and 1.0V it should be a regular scan if it is slow to move between either extreme the sensor is cabbage test this with the car at 2000rpm.
On a little science side note the eggey smell you are getting from the cat is Hydrogen Sulphide, this is caused by the over production of hydrogen mixing and combining with the sulpher in the fuel at the extreme temps in side the cat. It is an indication of over fueling.
