Home > General Chat > 3 Clock Connection
Markie_D
Member #: 1660
Formally Mini_Uk
London
I'm after the black wired connection thing, that goes into the back of the 3 dial 1275GT clocks ?.
They all need re-connecting, as my indicators have stoped working etc.
Where Can i get a new one from ?, or just the connecters.
as i can't open the old connections that the wires go in to.
Shit Happen's
turbogt
Member #: 2314
cumbria
Allrite mate have you not got an old loom lying about that you could cut it out of then solder into your own loom? Should be like for like with colours aswell. A scrapyard or mini breaker like mini classics would prbably have one if you havent.
This connection is the same on all the minis fitted with the clocks in front of the driver, whether 2 or 3 clocks, so it shouldn't be too hard for you to get hold of a used one. Otherwise somewhere like Autosparks that supplies full replacement looms may be able to sell you a new one.
hario
Member #: 2885
If you look into the end of the plug there should be two small tangs that each pin uses to locate into the housing, just push them in with a paperclip or similar and remove pin, then solder new wire on, reinsert and your done *tongue*
Markie_D
Member #: 1660
Formally Mini_Uk
London
Tried that, was looking good, till 2 connctors snaped bending it back.
mini classics has some. the other companys don't do them anymore.
Thanks alot :)
Shit Happen's
