Home > Help Needed / General Tech Chat > injector pockets
anyone ever made some?
yep,
just drilled a 14mm hole up some solid, and put a slight taper at the inlet with a cone cutter so the o ring would go in.
sounds so easy ill pass it onto a mate of mine
going injection wolfie?
inlet fanimould for a k headed turbo???
ooooo k headed long stroke turbo.........evil!!
Edited by James_H on 7th Jan, 2009.
might do
might fit the scooby lump to my camper
might fuel inject a ride on mower *wink*
I've done it before mate, pop down one evening, and I'll sort it out for you. I've also got a jig made up to hold them, when welding to manifold
ah scooby lump, of course!
in that case, i'd say of the cuff that (assuming you have a plenum for each bank) you want plenums of about 1500cc each.
slater
Member #: 1291
Suffolk / Birmingham
Im just about to do some on my fiesta, drilling the holes is easy but im more interested in working out the right angle/how far down the port they should go (and what deapth to have them at)
i welded the bosses on first and am going to drill them on the mill at some point.
Mikes1098
Member #: 2190
South Carolina, USA
I was going to comment -- but then I lost my train of thought watching your avatar! HOT DAMN!
