Home > FAQ / Knowledge > 1275 motor
JsfMini.MT
Member #: 4487
Mtarfa,Malta
Since i haven't ever seen a 1275 opened up what makes it recognisible from the 998?
It's a mini thing you will not understand
its bigger!
The bore spacing between the cylinders is pretty much identical, rather then on a 998 where there is a big gap between cylinders 2 and 3
Con rods are split at 90 deg to the beam, not at an angle like the small bore ones.
Externally, apart from certain early Cooper S blocks, the 1275s have a solid "back" over the cam followers whereas the small bores have two removable pressed steel plates.
