Home > Technical Chat > DIY balancing
bigmini998
Member #: 2830
Costa del Northern Ireland :)
on stripping down my 998 turbo I found a crack in no3 bigend so im on the hunt for a good crank or engine.... one step forward two back*frown*
thing Is it possile to balance your own crankshafts at home? or is there any special machines needed to do the job?
is it a case of setting the whole rotating assembly on a spit with bearings at either end? like old fashioned wheel balancing? or am I being stupid*indifferent*
I just dont like forking out for someone else to do things for me when i can do it myself for free*happy*
cheers lads
That mini is determined to Kill me!!!!
Eh, no!
Specialist machinery only!!
bigmini998
Member #: 2830
cheers for the fast reply :)
ministef1
Member #: 1791
Cranleigh, surrey
i wouldn't say no straight away, dpends if you are a highly qualfied engineer and know what your doing. I know people who balance there own cranks.
"Cars are a lifetime of pain"
i have watched a crank and flywheel being balanced at home, a jig was made to support the crank using skateboard bearings, holding up the crank/flywheel assembly around the main bearings so it can spin very freely, it was then spun, when it stopped a marker was used to mark the very bottom, spun again marked and again 3 or 4 times you should be marking the same spot every time if you are its heaviest at that spot and a small amount of metal removed
this is repeated untill it stops where it wants lol
disclaimer *happy* i would just get it done for me on a balancing machine but the guy i watched do it is very experienced has done it many times and claims he can get it better balanced for what he wants?? lol he currently has about 280hp at the flywheel and revs to 9k (its not a mini btw)
he tryed to balance a turbo once.. yeah that went very wrong :)
The process described above is perfectly feasible, BUT, it is static balancing only.
A crank/flywheel/pulley assembly needs dynamic balancing to actually be properly balanced once it is rotating.
Just like the wheels on your car need a weight on the inner rim and the outer rim to be properly balanced, not just a single weight opposite the heaviest point.
I knew, I just knew that there would be some one out there who thinks its perfectly satisfactory to have 'balanced' a crank/ flywheel at home, with a Black & Decker and a needle file *laughing*
Edited by Sprocket on 9th Jan, 2009.
I balanced my own crank, but i borrowed time at my pet machine shop, on their machine *hehe!*
Get it done properly (dynamic balance) or leave it alone.
hey, i never said i would do it my self*happy* just that it can be done
although the penny has just dropped and i now know the difference between dynamic and static balancing, i though dynamic balancing was the (fly/crank/rods/pistons) being "staticaly balanced" *happy*
bigmini998
Member #: 2830
sounds like some things should be left to the experts cheers fellas. now to find a crank..... they arnt that easy to find anymore :(
tbh a 998 a+ block/rods/pistons might be the fastest and cheepest option, i have not seen a 998 crank on its own for a long time but you cant give the blocks away, well actually you can lol wil took care of mine :)
also a 1098 crank is a straight fit
I have a spare 998 A+ crank. It needs a regrind but otherwise OK.
bigmini998
Member #: 2830
Thanks for the offer my friend came up with the goods. a 998 city e automatic! :) that he had lying in a field.
the crank is perfect and just needs a polish and a balance. taking the lot to the machine shop tomorrow :) not long now until im on the road again.....
really? thought autos had dif cranks?
All A series transverse cranks are no different, auto or manual
bigmini998
Member #: 2830
Autos are a good source for parts! they run huge big oil filters as standard the thrusts are usually perfect and autos arnt usually thrashed the same way as a manual with a 17 year old behind the wheel!
Hedgemonkey
Member #: 360
Interesting point. I've overheard conversations about "home machining" of cranks and rods. Like wedging your own crankshaft with an angle grinder. Obviously, it takes an immense amount of marking, measurement and balancing via many means.
I gather components can be quite out of whack for starters. I'm not sure to what degree. You should be able to get it pretty accurate though.
I wouldn't use a crank modded in this manner!
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
As Rod said though you can only achieve static balancing by these methods. Dynamic balancing is much more complex
On 30th Apr, 2010 Rod S said:
Gary's description is best
Turbo Shed
Member #: 30
Epsom, Surrey
you can do anything on the cheap if you try but to what end? ballancing as above will work but to what accuracy.
a friend offered to try and ballance my turbo as long as he could get the ballancer to go that small, but then he asked what speed should it be run at, tollerance etc etc
GaryOS
Member #: 2810
Dublin, Ireland
Again, I find it hard to believe that anybody could accuarately dynamically balance something like a compressor, turbine and shaft assembly by manual means.
Even if a crank is statically balanced it will remove the surface hardening in the relieved areas. Therefore, it will require re-hardening afterwards by professionals and it still won't be balanced dynamically.
So anybody thinking of DIY balancing, stop being a miserly fuck and get it done professionally. DIY will always be a compromise
Turbo Shed
Member #: 30
Epsom, Surrey
my friend works for an aircraft engine company and he was going to balance my turbo on the machine at work. what i was getting at is even with the right tools you still have to know what to work to otherwise your best of getting it done properly
GaryOS
Member #: 2810
Dublin, Ireland
Ah, I just took that completely the wrong way. Oops :$ . In that case, it's a very good point
