Home > General Chat > lowering car....
would it be posible to use some wood or metal to go from the shock mount on the top arm to the top shock mount to get an idea of the hight of the car w/o damage? the car has no glass, engine interior ect just want it sitting low to get an idea and some more motivation.
is this stupid or have people doe this before?
paul
dont see the point mate its just wasting effort
you need hilos and lowered dampers anyway so better off doing the job once and just fitting these you can fuck about with ride height all you want then
just to try and get some more motivation into it, im getting alot more now with time off and trying to get it to welding. just make it look better while its sat in the garage :)
slater
Member #: 1291
Suffolk / Birmingham
go for it.
Mini_Andy
Member #: 432
why would you want t do that? the only way ive ever found of doing it is wheel off, adjust, wheel back on stand back and start the process again. (using the same turns for the other side)
Coupe
Member #: 2178
Leyland, Lancs
If I've read it right - he just wants to see how it'll look in the flesh quickly without putting in the cones and trumpets etc....
yep i get the point however you would have to remove the dampers and suspension cones, if your going to go to that effort why not throw on some hilo's rather than fucking about with bits of wood rods ect if your going to lower hilo's will have to be fitted anyway at some point
Edited by wolfie on 9th Jan, 2009.
Coupe
Member #: 2178
Leyland, Lancs
I just assumed that he didn't have the cones and trumpets fitted at the moment, hence asking if he could do it this way.
put the wheel on. jack wheel up to the desired height. job done nice and quick.
no time wasted faffing around making something that is essentially pointless
pot_dan
Member #: 326
bradford, west yorks
its true, if you taking the old trumpets out you may aswell just put hi-los on there and then especially since there about 30 quid anyway. its not more than a days work and i work really slow! lol
http://turbominis.co.uk/car/105/
im not going to be using hi-lows or cones, which is why i thought about this :). i dont want to spend out on coilovers yet as i dont need them. i wanted abit of a lepo idea in my head to help things along
pull out the cones and trumpets and ill chop them down a bit
Edited by wolfie on 13th Jan, 2009.
legend, would you like some tokens for this?
manley love
erm... ill see what i can do... lol
