Home > Beginners Tech > crank pulley bolt
Simon
Member #: 1865
Norwich, Norfolk
im putting together an engine with a new crankshaft but the pulley bolt is to small in diameter, to make sure i wasnt going mad i tried the bolt in the end of the crank on my spares engine and its fine, so the new need a bigger botl, i cant find any larger crank bolts anywhere, im lost :S
Edited by Simon on 10th Jan, 2009.
Id be lost too. Contact the crank supplier
Paul
philc
Member #: 1346
bromsgrove
i may have one you can try
Three options:
Did 998 & 1275 cranks have the same thread? (I think so but I'm not 100% sure)
The crank has been drilled & tapped in the past (possibly due to the thread being stripped)
You've got the wrong bolt mate.
That's about all I can think off.
Scruffy
Member #: 328
Seaford Rise, South Australia
Let's have a picture of the bolt you are trying to use against a ruler showing length and width (diameter)
On 5th Sep, 2011 Vegard said:
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Don't the SC twinks use a longer crank pulley bolt. I could be talking shit but I think I remember reading that. Anyway, if they do and your first few threads are knackered you could use one of those.
I'm using a 998 crank pulley bolt with a trigger wheel, Cooper S damper and pulley and had no issues so I dont think 998s and 1275s have different bolts
On 30th Apr, 2010 Rod S said:
Gary's description is best
