| Home > General Chat > painting the car next week, compressor info. | |||||||
21st Jan, 2009 at 10:56:42am
Hi, painting the car next week, the compressor i have isnt up to the job, i have rented one in the past but cant remember the required / minimum cfm and litres for a compressor..
Edited by MarkGTT on 21st Jan, 2009. |
21st Jan, 2009 at 02:51:08pm
depends on the gun you are using to an extent; mine is a 2hp with a 100lt tank and works fine - i think it has around 9CFM |
21st Jan, 2009 at 03:30:30pm
And whether you are using an air fed mask/hood (as you really should be if spraying 2K).
21st Jan, 2009 at 03:42:17pm
True, It depends on the guns you are useing. I switched from suction to gravity fed and the air demand dropped right off.
Edited by Mr Joshua on 21st Jan, 2009. Own the day
