Home > Help Needed / General Tech Chat > What Subframe?
98harbourc
Member #: 4976
Neston, Cheshire
Hi, if i was to fit a metro turbo engine to my mini, can i use a standard front subframe or does it need a modded one? if a standard one will do, do i need any extra parts?
Thanks Chris
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Search, thats a very basic question which has been covered approxiamtely 7 million times before
On 30th Apr, 2010 Rod S said:
Gary's description is best
98harbourc
Member #: 4976
Neston, Cheshire
sorry new to site, couldnt really find anything
GaryOS
Member #: 2810
Dublin, Ireland
No problem. Searching on here is great though. Theres answers to almost every question you could ask.
I'm going to answer this one as I'm not so sure a search will reveal the answer- I've not seen it asked before as most people take it for granted.
SO-
Standard one can be used with no problems.
98harbourc
Member #: 4976
Neston, Cheshire
Cheers thanks for the help
Mr Joshua
Member #: 1954
Luton Bedfordshire
Tom The answer was simple the question unbelievable.
Edited by Mr Joshua on 22nd Jan, 2009.
Own the day
Why? Seemed reasonable enough to me, written in coherent english with punctuation and a thanks at the end, its better simply in the level of politeness than many questions we see on here in my experience.
some people start with not as much knowledge as others.
i dont think its a good idea to start slating people that really do seem to want to learn, just because they are starting off with less knowledge than others.
Mr Joshua
Member #: 1954
Luton Bedfordshire
True, and it has taught me a valuable lesson, as you said the things some take as a given throw up question marks to others. My point, no question is a bad one. Keep asking away fella
Own the day
I remember the first couple of posts I made on here were utter shite! still I hope there is some pointfullness in the other 1000 odd:)
Mpi front subbys i belive have the engine slightly futher forward, this will give a litlle more room around the turbo area :)
Mr Joshua
Member #: 1954
Luton Bedfordshire
And get an adjustable engine steady to go with that subframe or you will hang your head in woe as I did.
Own the day
t3gav
Member #: 229
Gavin@minispares.com
kent
It was most subframes from 1990 onwards, depends if you want more room for the turbo or more room for intercoolers etc... Don't forget the engine steady as mentioned and the rod change.
