Home > Help Needed / General Tech Chat > setting up clutch
timboc
Member #: 2043
ok so i've finally got round so sorting out a lightened flywheel and pressure plate just wondering if people set them up in a differant way for fast road or will standard do??
giallofly
Member #: 164
The Stig..
Newport Pagnell
No, just as you would a standard clutch set up. All the "squeezing" points should be the same, just a slimer version of it with the same working principles...
I'd allways machine a tad off the back plate posts for a better "squeeze"
JF.
yes take 1.5mm off the 3 back plate lugs
