| Home > General Chat > weber alpha ecu | |||||||
16 Posts Member #: 567 Member |
25th Jan, 2009 at 11:41:26pm
hi i have a weber alpha ecu which i am plannig to use on my next project does anyone know were i would be able to get the softwhere for it so i dont have to spend hours on rolling road sessions to get fuel and timing set. i also need wiring diagrams as it never came with them. |
26th Jan, 2009 at 12:27:32am
You could start here?
Edited by Sprocket on 26th Jan, 2009. On 26th Oct, 2004 TurboDave16v said:
26th Jan, 2009 at 06:21:56am
You can't get the software for these ECU's, only the dealers can access them to change things, a ridiculous setup if you ask me and also makes them almost worthless second hand.
26th Jan, 2009 at 08:18:05am
Yes, a good system, let down by the fact you can't home tune. http://www.twin-turbo.co.uk
26th Jan, 2009 at 09:58:16pm
thanks for the help. what systems do you rcomend to do both ignition and fuel. i have omex 100 on my blue car and dont really want to spend the £200 to have it upgraded to a 500 unit would rather leave that on the blue car and have another system on the new project. |
26th Jan, 2009 at 10:12:41pm
I've experience of Emerald and DTA and would use either again.
26th Jan, 2009 at 10:19:37pm
what are you running on the don as i have the proper twin cam but only a small valve version also have gt1752 a 1293 block with forged je pistons jk gear set and drops quaife diff etc.
26th Jan, 2009 at 10:58:47pm
The Don uses emerald, as do I on my car Team www.sheepspeed.com Racing
26th Jan, 2009 at 11:02:54pm
hi jim long time since we have spoke |
27th Jan, 2009 at 10:27:07am
27th Jan, 2009 at 10:40:35am
Car is going well Stu, I'm using the K3 ecu £580 + vat new
27th Jan, 2009 at 11:21:05am
I like the DTA
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
27th Jan, 2009 at 11:33:06am
Good thing with the emerald is you can switch between different maps, I think you get a switch with 3 positions which you can load different maps onto etc....i like that feature, Means you don't have to carry a laptop round with you! changing maps etc.... "Cars are a lifetime of pain" |
27th Jan, 2009 at 11:51:16am
On 27th Jan, 2009 ministef1 said:
Good thing with the emerald is you can switch between different maps, I think you get a switch with 3 positions which you can load different maps onto etc....i like that feature, Means you don't have to carry a laptop round with you! changing maps etc.... Stef, how do you change maps without using a laptop to access the ecu.? i should now this but i don't lol. i don't see any switches on the ecu in the Don, carl |
27th Jan, 2009 at 12:09:13pm
you can do it carl, I do it on mine, the ECU can hold three different maps, by flicking a switch you can change to another map. Team www.sheepspeed.com Racing
27th Jan, 2009 at 12:14:55pm
You can do it carl, you wire a switch into the inputs, I never bothered as we don't really need it, but we could do it.
27th Jan, 2009 at 12:23:36pm
On 27th Jan, 2009 Tom Fenton said:
You can do it carl, you wire a switch into the inputs, I never bothered as we don't really need it, but we could do it. I knew this shit really , i was just testing . |
27th Jan, 2009 at 12:46:19pm
Did we pass the test oh great one? http://www.twin-turbo.co.uk
27th Jan, 2009 at 01:18:03pm
Jesus, did we know something the great one didn't, I'm in shock!!!!
27th Jan, 2009 at 01:40:06pm
it was red herring mate, clearly a switch and associated wiring will add to many grams
Jesus, did we know something the great one didn't, I'm in shock!!!! Crystal Sound Audio said:
27th Jan, 2009 at 02:01:28pm
i guessed as much, for road cars it could be handy, turn the boost down and run a leaner more economical map? then when you want a race, yank the boost up and change the map? that would be my only reason? plus maybe a map for nitrous use as well? If i ever go 16v, i will head down that route.... "Cars are a lifetime of pain" |
27th Jan, 2009 at 05:15:42pm
Carl is in charge of ensuring minimum usage of ferrous materials in the cars, I am in charge of electric trickery!
what was the damage and what model emerald ecu you using? how user friendly is it. etc hows the car going.
