| Home > Technical Chat > T2 Boost | |||||||
52 Posts Member #: 4982 Advanced Member |
26th Jan, 2009 at 08:31:21am
Ok...
26th Jan, 2009 at 09:14:23am
It depends which T2.
In the 13's at last!.. Just |
26th Jan, 2009 at 09:15:12am
7:1 is a bit low, especially if you want tractability, I'd aim towards 8 - 8.5.
26th Jan, 2009 at 09:15:32am
I'm sure I will be corrected if wrong but 7:1 is a very low CR for your application
26th Jan, 2009 at 09:26:53am
I think that you will need to upgrade the turbo thrust bearing for anymore than 15psi boost. Besides, you should be able to get 150hp at the flywheel from less than 15psi.
Edited by Paul S on 26th Jan, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
26th Jan, 2009 at 09:33:24am
The T2 will run 15psi, but compared to modern turbos, it's not very efficient at these levels of boost. 12psi is a nicer zone to be in. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
152 Posts Member #: 1074 Advanced Member Northamptonshire |
26th Jan, 2009 at 01:56:40pm
I am curious why everybody runs such low CR.
26th Jan, 2009 at 02:06:50pm
Thanks for the kind advice.
26th Jan, 2009 at 02:09:08pm
MG Metro cam makes and excellent turbo cam. As long as it is good condition. If something is worth doing, it's worth doing half of. |
26th Jan, 2009 at 02:17:19pm
On 26th Jan, 2009 matnrach said:
I am curious why everybody runs such low CR. I am running around 9.6:1 and 1bar and I think this is low. Response if really good (will be putting a 266 in shortly to improve low end torque). I do however use 98 Super unleaded + Millers (which includes a mild octane booster) and a charge cooler that sees around 20deg max above ambient My ignition is mapped at around 10-11deg retard for 1bar. Do you mean you run 10-11 deg advance at full boost? I guess this is why you have no pinking. There's lots of reasons why you can run a higher CR with high boost, having a wild cam for one, or retarding your ignition massively for another. But all these things are bad for power. 8.5:1 is a good compromise for high pressure applications, and 9to9.5:1 with moderate boost is good fr road aplications IMO. What sort of power do you make with 9.6:1 and 15psi boost? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
26th Jan, 2009 at 05:29:41pm
I would have thought dropping the boost and running more advance would be a better option.as well, it's always a compromise! |
26th Jan, 2009 at 05:35:53pm
I run 11degrees retard from base N/A map so around 21deg advance at 1bar.
444 Posts Member #: 2885 Senior Member |
26th Jan, 2009 at 07:42:32pm
On 26th Jan, 2009 wil_h said:
The T2 will run 15psi, but compared to modern turbos, it's not very efficient at these levels of boost. 12psi is a nicer zone to be in. ..but they are actually cheaper than chips! |
27th Jan, 2009 at 07:51:47am
On 26th Jan, 2009 Paul S said:
I think that you will need to upgrade the turbo thrust bearing for anymore than 15psi boost. Besides, you should be able to get 150hp at the flywheel from less than 15psi. Pistons are best from Minisport - Australia - do a search for "Hypatec" Aim for 8.5:1 CR if you are planning on a good intercooler. The 276 cam is too radical - use a 266/255 or SW5. |
27th Jan, 2009 at 08:16:15am
were running up to 30 psi on a t25 in a discovery .theres a noticable power increase going from 25 to 30 psi .big ic. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th Jan, 2009 at 08:42:31am
On 27th Jan, 2009 B15MJO said:
Hi, Ive emailed Minisport Australia and they only guarantee pistons up to 7.5 psi and they have a 7cc dish. Is there a specific model of piston you recommend Paul S ? Mike On 26th Jan, 2009 Paul S said: I think that you will need to upgrade the turbo thrust bearing for anymore than 15psi boost. Besides, you should be able to get 150hp at the flywheel from less than 15psi. Pistons are best from Minisport - Australia - do a search for "Hypatec" Aim for 8.5:1 CR if you are planning on a good intercooler. The 276 cam is too radical - use a 266/255 or SW5. No one will guarantee pistons for high boost. I believe that the best pistons are the larger sizes - equivalent to 73 or 73.5mm. They are a better design with oil holes rather than slots. The +0.020" etc look like standard replacement pistons. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
