Home > 998cc > toyota ct9
bigmini998
Member #: 2830
Costa del Northern Ireland :)
ive just been offered a toyota ct9 turbocharger from a toyota starlet. has anyone ever used one on a mini? 1275 or 998?
ive searched but cant find anyone using on in this site
the starlets run 0.6bar on a 1300 dohc engine thought it might make a nice turbo for a 998 :)
Cheers fellas
That mini is determined to Kill me!!!!
turbominij
Member #: 2104
Essex - UK
i dont know much about this but my friend has run 1 bar boost on his ct9 starlet and held the boost well.
i do no the inlet and outlet diamiters are very small on them if i remember rightly the they are in the region of 43 as we had problems getting a silicone reducer from 45-51mm to fit tightly.
the oil feed and oil drain are both on the bottom veryclose together and they are also 'water cooled'
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
bigmini998
Member #: 2830
I will mabye give it a pass then, think i will have a look in my local scrapyard to see if i can find and unwanted turbos
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
If I were you I would take it. You can never have enough turbos. My GT15 for my current build has a 41mm compressor outlet. I'm just going to make my own reducers
On 30th Apr, 2010 Rod S said:
Gary's description is best
bigmini998
Member #: 2830
I suppose you are right there it might come in handy some day........ :)
if all else fails i can always sell it on again
GaryOS
Member #: 2810
Dublin, Ireland
It will be a good excuse to build another engine *happy*
bigmini998
Member #: 2830
Think my next engine will be a ford 302 v8...... a ct9 might be a we bit small I could do with four of them *Yes*
