| Home > For Sale > Solid Tower Mounts | |||||||
29th Jan, 2009 at 11:43:48pm
Never used £10 posted, only selling as I've made some custom ones or £5 if you can guess why I've made custom ones.
29th Jan, 2009 at 11:59:37pm
On 29th Jan, 2009 Rob H said:
£5 if you can guess why I've made custom ones. These ally ones you are selling are too thin therefore when the bolt bottoms out on the subframe, there is still a gap between the mounts
and for £5 you can keep them, if that is the case. I already have a set. all they need is a washer On 26th Oct, 2004 TurboDave16v said:
30th Jan, 2009 at 12:01:04am
you have made custom TI ones?
30th Jan, 2009 at 12:01:37am
30th Jan, 2009 at 12:11:51am
On 30th Jan, 2009 James_H said:
you have made custom TI ones? Don't be silly titanium is twice as dense as aluminum. Isambard Kingdom Brunel said:
603 Posts Member #: 1938 Post Whore near Dundee |
30th Jan, 2009 at 12:14:18am
its a twin bolt subframe?
30th Jan, 2009 at 08:08:21am
you have made some from nylon? Team www.sheepspeed.com Racing
172 Posts Member #: 1600 Advanced Member Portsmouth, Hampshire |
30th Jan, 2009 at 09:52:44pm
you were bored,
30th Jan, 2009 at 10:01:54pm
you made them because want your own section ALA Carl Austin?
4th Feb, 2009 at 08:13:22am
youve cut the little ring off the tower mounts on the subby? Sort of, I've not got round to cutting the rings off the subframe yet but I am mounting the frame direct to the bulk head, hence no lower mounts and bigger upper mounts. As an aside I save about 400g in the process. Isambard Kingdom Brunel said:
