Home > General Chat > mb split rim nuts and bolts
nick1275
Member #: 1615
Ferndown, Dorset
a couple of mine have sheared off on the inside, are they special in anyway or is it a case of finding one that fits?
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
ministef1
Member #: 1791
Cranleigh, surrey
you want to ring mb and get some unbreako bolts, my friend graeme had this problem.....don't fit low grade stainless or steel ones in there...
"Cars are a lifetime of pain"
philc
Member #: 1346
bromsgrove
http://www.mb-racingwheels.com/
I had to change mine to some uprated ones. The original ones were junk. Just find some decent 6mm allen head ones.
Scruffy
Member #: 328
Seaford Rise, South Australia
Odd that I never had this issue with my Spectrums! Maybe when MB started making them again they fitted shite?
On 5th Sep, 2011 Vegard said:
Never had the problem with my Spectrum either, they are s/s. I have heard a few stories of MB bolts breaking though
Paul
dont get them from MB, unbrako are easy enough to get hold of.
I had 3 of mine shear which made the tyre come off the rim!
to be fair they'd had a fair bit of road use so probably due for a change.
nick1275
Member #: 1615
Ferndown, Dorset
cheers chaps i shall look in to it, heres a pic of exactly whats happend
Hmmm weberyyy
Umm, so you are only using 12 instead of the possible 16 holes.
That may be telling you something.
nick1275
Member #: 1615
Ferndown, Dorset
theres only 12 possible fixing holes on the 'face side' of the wheels, should the inner half of the wheel be fixed on with 4 more then?
Hmmm weberyyy
If the outer rim and centre are only drilled for 12, then you have to live with that.
My SC rims have 16 bolts.
MB wheels have only got 12 bolts.
antman
Member #: 358
Snetterton, Norfolk
Of the mb wheels i have seen the rims are drilled for both a 12 and 16 hole pcd. I haven't actually seen centres for a long time for the mini centres but we use them all the time at work and have 13" 16 hole wheels for the f1s.
