Home > General Chat > Tow Ball Sizes
I bought, some time ago, a detacheable tow bar adapter for my T5 off eBay.com
I went to hitch it up to my bike trailer tonight, and the sodding ball seems marginally too big, only a fraction of a mm or so, just enough to prevent it locking on...
I tried it on several other trailer hitches and the same result...
Do the yanks use a bigger tow hitch to us?
If so, I bet they think its really big and clever eh?
All tow balls shound be 50mm
arse, I think mine is the 2" one...
http://en.wikipedia.org/wiki/Tow_hitch
Bin it and Buy a gold type aproved one, depending on your car, that is what you should have. anything later than 1996 should be type aproved
Edit, just clicked that you said it is detachable. For a Volvo T5 it should be metric 50mm.
Edited by Sprocket on 1st Feb, 2009.
ill get the calipers on it tomorrow
I bought from the US though sprock, so it might be a model to fit their slightly larger hitches maybe?
ill try chipping off the plasticote finish if I get desperate, nothing seems to be going easy this week....
Whoopsie *oh well*
Scruffy
Member #: 328
Seaford Rise, South Australia
You cannot mess about with tow balls ask Mr Wakeley and his was in good nick *frown*
On 5th Sep, 2011 Vegard said:
Yes I agree, Jo get the proper thing mate.
Yep - tow balls here are 2". You are screwed uless you're towing a really, really old trailer...
Yes, my mate had a Jeep Wrangler a couple of years ago and wanted an authentic Jeep "chrome" towball so ordered it from the USA....
When he showed it to me and (only then) told me he'd bought it from the USA, I said ".... it's not going to look quite as good once you've filed all that chrome off......"
graemec
Member #: 1424
Carnforth, Lancs
There should be no finish to the towball, it should be cleaned up back to bare metal and then lightly greased - unless using a stabiliser system that 'grips' the ball which require the ball to be clean and dry.
If there is a plasticote finish it would wear off in use and then the coupling would become loose.
its got some sort of nylon coating on it, ill snap a few pics tonight and get its exact measurements
You're suposed to remove the plastic cover before you connect the trailer *hehe!*
Sorry
Scruffy
Member #: 328
Sorry
PMSL!
arse i do have a yank ball
i reckon i can shave off a few microns by taking the wire brush to nylony finish
fucking yanks!!!!!
