| Home > Ebay items For Sale > Piston Buttons | |||||||
10th Feb, 2009 at 07:45:37pm
Never seen anyone selling these before:
10th Feb, 2009 at 08:49:14pm
unfortunatly through experience , that design will not last very long, they are too thin on the outer lip, |
10th Feb, 2009 at 09:34:29pm
do you use the shorter gudgeons then carl?
Edited by joeybaby83 on 10th Feb, 2009. "Turbo's make torque, and torque makes fun"
10th Feb, 2009 at 10:42:54pm
i reduced the length of my pins by 8mm if i remember correctly,so end up with a nice thick outer section, if i were to do tha same again, i'd use some good used pins from the standard metro pistons as they are shorter still due to the standard flat sided design.
10th Feb, 2009 at 11:27:22pm
I just had Selby make me eight for a set of MEGA pistons. I'm not teaching you to suck eggs Carl, but wouldn't Rob have some experience on this? On 13th Jul, 2012 Ben H said:
11th Feb, 2009 at 07:36:14am
I'm pretty sure Carl knows more than me, my buttons are still sat on the shelf waiting for me to build the engine. Isambard Kingdom Brunel said:
11th Feb, 2009 at 08:30:25am
On 10th Feb, 2009 Vegard said:
I just had Selby make me eight for a set of MEGA pistons. I'm not teaching you to suck eggs Carl, but wouldn't Rob have some experience on this? Firstly why would he,?. and secondly make sure you only use them on a small over bore because when the thin ends either wear off or break up you'll be able to machine the grooves out of the bore, if youve never run floating pins before on a mega piston, then i have more experience than you and i'm giving you my advice as a friend not a salesman, the ends need to be a lot thicker, and shame on you for using someone else for such a simple machiining job carl |
