Home > General Chat > Ok here's my turbo
MajicMini
Member #: 72
Does my turbo look like it has been butchered by the previous owner?
Sorry about the picture quality
this bit looks home made,
Is it an oil feed? *oh well*
Or is this the oil feed?
http://www.ezshots.com/members/calibraturb...urboboy-160.jpg
(edited by Alex, Huge image!!)
U can just about see on here that the Part shown above bolts onto the bottom of the turbo, but is it the right part? only there's 2 bolt holes there that aren't used, one of which has been snapped off.
http://www.ezshots.com/members/calibraturb...urboboy-161.jpg
Also theres 2 little bronze outlets on the main outlet which goes to the carb inlet. What are these 2 bronze connections for?
Thats all I can think of at the moment
Thanks
Edited by AlexB on 14th Sep, 2003.
Holy Sh1t that is one majorly f**ked with turbo...
The banjo bolt is the inlet, and is meant to be at the top, with no more than 25degrees from vertical instanaltion angle. That looks like a 180degree instalation angle...
that piece of sh1t pipe is meant to be where the return is...
Throw it in the bin. If it's been run like that, it'll be pretty f**ked. Lord knows what other botched surprises are contained elsewhere...
ProjectPunto
Member #: 22
makes you wonder why he didnt just take out the little fans inside.. they do interrupt the airflow you know *tongue*
MajicMini
Member #: 72
*crying* argh damn, i really wanted that
Nothing else on it has been taken apart, just those 2 parts. The owner told me he was to stingy to buy the correct parts, so he made his own.
He even used silicone instead of a proper gasket on the home made bit lol, yeeeehaaaaaaa cowboy!
