Home > Help Needed / General Tech Chat > Clutch Diaphragms
I'm going through some clutch diaphragms as the moment, and none of them have any paint on them so I don't know what is what. Can you tell what spring is fitted by measruing the thicknes off it?
You need someone at minispares with a mic to help you (gav??)
Whilst on the subject... I have one with a blue stripe and one with a green stripe. Are they standard ones?? One came from a 1275 and one came from 998.
green - stock small bore engines
blue - stock big bore engines
Don't suppose you could measure the thickness of the springs so we can build a table
Blue spot is standard 1275 diaphragm and green spot is standard 998.
from our good friend google :)
EDIT: Beaten to it. *tongue*
Edited by John on 12th Feb, 2009.
My single grey is 2.5mm thick and has a red splodge of paint on it
Green - 2mm
Blue - 2.1mm - 2.2mm
My verniers are not digital so measurements are not as exact as they could be.
Can we put approx max banana/curly wurly ratings on the table so that idiots like me don't ask stupid questions :)
EDIT: Why can't I spell/type/read ???
Edited by apbellamy on 12th Feb, 2009.
Red splodge of paint just to keep you guessing, nice!!
Thanks for the info guys,
miniminor63
Member #: 672
The oversills police
Oslo, Norway
also there are 3 strengthening pieces inside it on the grey and double grey.
RTS Double Verto 4.4mm *Yes*
That is very strange. A lot of (OE) clutch manufacturers use the colour designation - and I don't know of any 'reds'.
You haven't got an orange per chance have you?
t3gav
Member #: 229
Gavin@minispares.com
kent
Yeah all of ours have grey and orange paint etc
Don't think so, it was sold to me as a grey. Don't think an orange would cope with what I throw at it. It may well have been splodged by someone at some point when balancing it.
Anton
Member #: 764
Staffordshire
Ill try and remember to measure my orange this weekend
Jay#2
Member #: 648
Northern Ireland (ex AUS)
My grey is 2.6mm, it's hard too measure though with the slight curve in the spring so it could be the same as Wil h's 2.5mm.
On 7th Nov, 2008 Nic said:
naeJ
m
