| Home > Help Needed / General Tech Chat > driveshaft retaining nut | |||||||
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
17th Feb, 2009 at 01:24:57pm
Hey guys, can anyone tell me what torque setting i need for the driveshaft retaining nut (disc type) and does it have to be backed off at all?
1972 998 TURBO SLEEPER |
17th Feb, 2009 at 01:28:28pm
if its the x holed drive shaft its 150lbft plus what ever to get it to the next hole on the castle nut, if its the single hole drive shaft its 200lbft +
Edited by Brett on 17th Feb, 2009. Yes i moved to the darkside |
17th Feb, 2009 at 01:50:49pm
wow thats high. didnt think tapered bearings could handle that 1972 998 TURBO SLEEPER |
17th Feb, 2009 at 02:04:51pm
TBH I'd torque it to the correct setting and turn it to the nearest hole whether it be clockwise or anti otherwise you could end up with some rediculously high torque setting to get the holes aligned....learned this the hard way on the way to Newquay! Edited by matty on 17th Feb, 2009. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th Feb, 2009 at 02:16:11pm
Cheers matty, ill have a go this weekend, finally gonna get the brakes on 1972 998 TURBO SLEEPER |
17th Feb, 2009 at 02:25:10pm
On 17th Feb, 2009 longy said:
wow thats high. didnt think tapered bearings could handle that These are not taper roller bearings like other old front wheel applications.... you aren't settting an end float, there is a spacer between the two bearings (or some have extended inner races to touch each other) so you are just clamping the whole assembly up, clearance already decided by the manufacturers. It has to be a high torque because the diameter of the shaft is small so the threads are coarse :) Schrödinger's cat - so which one am I ??? |
17th Feb, 2009 at 02:28:30pm
Once you have tightened the nut up so far you aren't really putting any more load on the bearings, as this is controlled by the inner races butting up hard against the spacer in the middle.
17th Feb, 2009 at 02:36:10pm
Thanks Tom that makes sense 1972 998 TURBO SLEEPER |
![]() 380 Posts Member #: 1835 Senior Member Thame, oxfordshire |
17th Feb, 2009 at 03:36:33pm
can i borrow yours chris? i need to do the same but my torque wrench dosent go up that high!! Edited by dan_up on 17th Feb, 2009. On 23rd Aug, 2010 Nic said:
Turbophil had a butt plug made that seemed to be suitable. He may have finished with it now and have it kicking around spare |
17th Feb, 2009 at 03:42:22pm
I might be thick but.....
20th May, 2009 at 12:07:16am
sweet, been looking for this thread for 20 mins
20th May, 2009 at 12:07:51am
p.s theres no crap in them either! "Turbo's make torque, and torque makes fun"
20th May, 2009 at 12:39:38am
Sounds like a bearing, does it increase when going round a corner? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th May, 2009 at 01:35:19am
curriculum vitae joints?
20th May, 2009 at 12:29:43pm
it seems to do away when cornering to he right, and stay present when cornering left, i.e. when the weight is on the osf?
