Home > General Chat > gas testing
b12
Member #: 247
Kent/Surrey Borders
this bad boy seems to work ok for me
i know it cant be fantasticly accurate but its not bad !
anyone else tried one ?
http://www.halfords.com/opd_product_detail...5&type=0&cat=67
TurboLessTosser
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
nearly good enough for mot setting...
but thats it!
alex
AlexF
looks good i was thinking of getting some thing like that as my car goes out ever month or less, so to able to check it with booking an RR every time would be good.
yes it would be interesting to know how accurate they are.
Doodmeister
Member #: 149
Alberta, Canada
Why not run something that shows you how the mixture is all the time…
And it’s cheap all you need is a Lambda sensor from the scrappy.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...7926214488&rd=1
yes i did think about that sort of thing, but i've been told by lots of people that they aren't worth having as they are not very accurate, that's why it's cheap*wink*
Doodmeister
Member #: 149
Alberta, Canada
Not being funny but that must be why ALL car manufactures use them to adjust the engines fueling via the ECU whilst the car is running. And even now days there using 2 of them one before and one after the CAT to adjust the EGR valve during the start and warm-up period.
One thing you don't see in new car's driving around is a CO meter stuck in the dash...
This is just my two penny’s coming from a guy who spend every working day mapping engines with and without Lambda feed back loop's to the ECU so take it as you will.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
The narrow band (2,3 or 4 wire) sensor are not accurate or fast enough to do mapping... but they can be good a telling u there is a serious problem.
Alex
AlexF
