| Home > Help Needed / General Tech Chat > I am going to crack up!!!! | |||||||
166 Posts Member #: 221 Advanced Member |
8th Oct, 2004 at 09:18:43am
Got my new gear box fitted and then got the car running real sweet. |
8th Oct, 2004 at 09:46:35am
Persevere with it buddy you know it will be worth it in the end.......
421 Posts Member #: 245 Senior Member |
8th Oct, 2004 at 05:44:46pm
check your ht lead from dizzy to coil |
8th Oct, 2004 at 07:03:13pm
I know how you feel m8, got an intermitant problem with mine at the mo. Started off as a little miss when on boost (but not all the time) got worse and worse, replaced ignition module,dizzy cap,rotor arm, coil, problem still there but not as bad!!!! plugs are a bit sooty so hopefully running a little rich and fouling plugs but until its sorted its getting me down a bit really:( Just stick with it, its always worth it when its running as it should. -MINI CLUBMAN 1380 TURBO- |
9th Oct, 2004 at 12:25:30am
Check the 12v feed to the coil ... had a similar problem on mine
12th Oct, 2004 at 09:19:38am
Ok guys I final managed to get enough motivation to try again.
12th Oct, 2004 at 09:25:29am
Sounds definately like a fuelling problem.
12th Oct, 2004 at 09:59:09am
Before the gearbox went I set the fuel pressure with a lo gauge to 4 psi at idle. I then drove the car about 150miles before the gearbox went arse up. The engine went well at all ranges. Could the regulator have become faulty. Will check it tonight again with the lo gauge.
12th Oct, 2004 at 11:14:40am
Quite possible that the fuel reg has shit itself, especially if it was an old one that you have only just started to use again. Also check that you didn't crush a fuel pipe by catching it with a trolley jack or something, sounds daft but I had a high-range misfire on my old clubman estate and changed all sorts before I found a crimped up fuel line.......
12th Oct, 2004 at 11:22:07am
could also be the ignition module. just because you have a spark in fresh air doenst mean there will be one under pressure |
12th Oct, 2004 at 02:46:06pm
Ok, nipped home at lunchtime and checked the fuel lines, there all ok. I did find the plenum pipe totally kinked, but dispite freeing this up the car still wont start. Could this have been part of the problem?
12th Oct, 2004 at 03:16:53pm
nope, wouldnt of thought so. that would only have caused leanout/misfiring on boost.
12th Oct, 2004 at 03:28:36pm
Plugs are very dry Iain. |
12th Oct, 2004 at 03:41:56pm
If plugs are dry then definately check pressure to the carb. Also if you can somehow rig up a bicycle pump to the regulator by applying a positive pressure to the sensing stub into the regulator, you should be able to watch the fuel pressure rise on the gauge.
12th Oct, 2004 at 05:21:55pm
Thanks for the help so far lads, much appreciated.
12th Oct, 2004 at 10:12:09pm
Dry has to be a fuel problem then. no question.
21st Oct, 2004 at 12:06:11pm
Ok..rounf three with the engine started last night!
21st Oct, 2004 at 12:42:49pm
Modules do break down...
21st Oct, 2004 at 12:45:39pm
Yeah definately.
84 Posts Member #: 255 Advanced Member |
21st Oct, 2004 at 10:02:51pm
1st time after rebuild, fitted "new" dizzy... fired a few time, and was happy. Came back to it next day, bugger all. Spent ages on it pondering..... opened up the dizzy, clean as a whistle. Replaced the module ... vrooom.
24th Oct, 2004 at 01:33:02pm
Thanks for the kind help lads.
24th Oct, 2004 at 09:08:39pm
any lucas dealer, check out a thread about dizzy curves, fairly recent. has a pic and part number of what you need |
25th Oct, 2004 at 11:27:24am
Thanks Iain,
