Home > Help Needed / General Tech Chat > Megajolt / Dizzy Drive
jonb_5
Member #: 3193
Torbay, Devon
I have taken out my dizzy this morning and just want to double check i have taken out the right drive but. People have said if i leave it in then it can cause huge problems. This is what i took out with a 5/16" bolt, is there anything else to come out??
Thanks
Jon
giallofly
Member #: 164
The Stig..
Newport Pagnell
You have taken out the right part, you just need to cap the hole it came out from..
Job done..
JF.
As above, correct part out but make sure you order the correct cap - the A and A+ caps are different.
You need one of these.
jonb_5
Member #: 3193
Torbay, Devon
Excellent - Thanks for the replies.
I have just measured up the dizzy as I am going to make my own blanking plug.
Have got access to a lathe and stainless at work so shouldn't be too difficult to make up.
Thanks again
Jon
Aluminium would be fine and a lot easier to machine..... after all, the dizzy was just cheap die-cast alloy (not even aluminium).
Make sure you get the O ring groove right, it's quite a small section ring if you're using the standard size, otherwise it will leak.
Rod.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Or good dose of sealant....
JF.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Never seen the sense in all of these elaborate blanking plugs/bungs.
A 27mm core plug available for around 15p does the job perfectly and looks completely OEM.
Rod.
What? Obviously it's an aluminium alloy :)
I just got one of these from MRA:
http://mra-minis.co.uk/product_info.php?products_id=109
For what it cost, I didn't see the point in asking somebody to mill me one. Quality and fit is spot on too.
Turbo Tel
Member #: 588
Delaware, USA
Brilliant.. sometimes its the simple ideas that are the best...
Small piece of advice with these. Drill a hole in the center, not all the way through, and tap it M8. This will allow you to pull the thing out again when you need to, as they are bloody tight!!
I love the core plug! that will be happening on mine!
Thanks very much for that one!!
seconded
philc
Member #: 1346
bromsgrove
just a thought, maybe worth keeping the dissy in until you have the mj setup and running, then take it out and blank off
Barrythebodger
Member #: 5062
Herts
seconded
thirded (if that's even a word?)
