| Home > Help Needed / General Tech Chat > supercharger and cam | |||||||
160 Posts Member #: 1085 Advanced Member Netherlands |
1st Mar, 2009 at 10:59:31am
Hi all,
1963 Cooper
1st Mar, 2009 at 05:05:37pm
that cams over the top as you say it will be a pig and very unpleasent to drive in traffic, .......... ok on the track balls out
1st Mar, 2009 at 08:08:25pm
it does apply to super charging too but too a lesser extent than turboing.
2nd Mar, 2009 at 09:41:43pm
thanks guys,
1963 Cooper
3rd Mar, 2009 at 08:43:24am
It's not the lumpy idle that's the problem, it's the overlap.What happens is that you blow the entire inlet charge straight through the engine and into the exhaust because both valves are open at the same time.
3rd Mar, 2009 at 09:19:32am
Listen to the advice from these guys or you could be very disappointed with the end result.
3rd Mar, 2009 at 10:58:07am
Benross has just enlarged the chambers in my head and done atop job of it. Well worth it. On 11th Feb, 2015 robert said:
3rd Mar, 2009 at 11:04:22am
3rd Mar, 2009 at 12:06:44pm
