| Home > Help Needed / General Tech Chat > problems fitting crank | |||||||
1st Mar, 2009 at 08:15:09pm
right, here goes;
1st Mar, 2009 at 08:31:28pm
Rob, put a dial on the tail as i was telling you about, see if theres any run out that could correspond to the run out on the centre main,
1st Mar, 2009 at 08:36:37pm
cheers Carl, I'll give it a try |
1st Mar, 2009 at 08:46:37pm
seems to me the certre maain is mis alighned,
1st Mar, 2009 at 09:11:57pm
On 1st Mar, 2009 mini13 said:
seems to me the certre maain is mis alighned, check the centre maiin is on thre right way rount, if it is try it the rong way, it may have been line bord with it on wrong. good point , are you putting the centre cap on gthe right way round Rob, the locating tangs on the same side |
![]() 87 Posts Member #: 3104 Advanced Member Glasgow |
1st Mar, 2009 at 09:32:17pm
Carl, Rob and I tried the centre cap the wrong way just in case and it wouldn't even look at it. It's amazing how many times you can remove and re-fit a crank in 3 hours!
14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell) |
1st Mar, 2009 at 09:37:15pm
less than a thou shouldn't give problems,
1st Mar, 2009 at 09:42:42pm
Have you got another crank you could try? On 13th Jul, 2012 Ben H said:
1st Mar, 2009 at 09:54:07pm
Take everything off and fit the cap to the block and tighten it down. Then feel with your finger where the cap and block meet on the inside. The locating rings can crush and make the cap over hang. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
Double post Edited by MikeRace on 1st Mar, 2009. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
1st Mar, 2009 at 10:01:38pm
Rob
2nd Mar, 2009 at 09:11:36am
its never easy - i'm going to head back up today and look like an idiot for another 3 hours |
2nd Mar, 2009 at 10:24:28am
I've had cranks lock up under torqing, trust me check locating lugs. Then build up the engine one cap at a time. Fit the cap torque it up and rotate the crank then move onto the next. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd Mar, 2009 at 10:57:53am
Obviously you've double checked the size of bearings? On 13th Jul, 2012 Ben H said:
2nd Mar, 2009 at 11:21:01am
I don't think the crank would even go in tbh 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd Mar, 2009 at 12:01:41pm
On 2nd Mar, 2009 Vegard said:
Obviously you've double checked the size of bearings? |
2nd Mar, 2009 at 01:15:06pm
I had this same problem, the centre main cap had sprung when machined for a centre main strap and went tight when torqued down. I had the block fitted with steel caps and line bored, a cheaper solution would be find another block.
2nd Mar, 2009 at 06:29:53pm
On 2nd Mar, 2009 Tom Fenton said:
I had this same problem, the centre main cap had sprung when machined for a centre main strap and went tight when torqued down. I had the block fitted with steel caps and line bored, a cheaper solution would be find another block. not on this occasion tom, iv'e just machined it for undecrown oil jets, |
3rd Mar, 2009 at 09:29:58am
thought I'd give you all an update;
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
3rd Mar, 2009 at 03:13:05pm
have you tried fitting the centre main on its own first? |
3rd Mar, 2009 at 03:59:27pm
OK, Keith went down the workshop this afternoon and has just phoned to say his crank is fine in my block.
