Home > Help Needed / General Tech Chat > converting rear brake drums to disks??
c2_mad
Member #: 4215
hello all
i would really like to convert the drums to disc brakes at the back, since im upgrading the front to 4 pot's i would like to use the old front discs and calipers. does anyone have any idea of whats involved in this? has anyone done it before? is there a guide? i tried the search botton but didnt find anything on the topic.
all help is apreciated.
thanks in advance.
No-one has done thos before and for a very good reason. The conversion would weigh more than the drum and all the added braking ability would be useless. You only need 30% of the braking force on the rear (well maybe upto 40%, but anymore and braking would be unstable).
Look at the KAD kit available for the sort of size that is needed.
I'd suggest if you are going to all the effort, some kind of scooter conversion would be best.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Sounds like a pain in the tits to be honest. You would need some form of mechanical brake aswell. As above, alot of work for no gain (except weight). Just buy KAD. If you really want rear discs I suppose you might be able to use VAG rear calipers with the winding pistons for the mechanical brake. It would still take alot of work though
On 30th Apr, 2010 Rod S said:
Gary's description is best
yep its the handbrake thats the difficult bit (not that te rest isnt!) although aparently on a pre 68 car you dont have to have a handbrake.
c2_mad
Member #: 4215
hi
thanks all for the replies, i always thought that disks at the back would improve the breaking by a lot., i really dont see how it would be unstable...
as for weight, im not to fussed about that...
where can i find this kad conversion? is it worth th cash?
the thing is mate, the mini is quite light on the back end. especially when made lighter, most of the weight tends to come off the back.
this means that it makes it easy to lock up the back end under heavy braking. a well set-up pair of drums will do this with too much bias towards the back, its not fun.
you might aswell yank the handbrake up on a high speed corner entry.....then try to control it.
here:
http://www.kad-uk.com/minibraking.htm
google search is nearly as good as TM search *happy*
Scruffy
Member #: 328
Seaford Rise, South Australia
I have to use a limiter on the rear of my car having 6 pots on the front and alloy drums and std linings - so don't waste your money!
On 5th Sep, 2011 Vegard said:
Ben H
Member #: 184
Melton Mowbray, Pie Country
Don't get confused into thinking that drums are rubbish either. They generally can out perform a disk in pure stopping power, unfortunately they can't get rid of the heat so degrade quickly.
The only reason you would put drums on the read, IMO, is to save weight, not for better braking.
http://www.twin-turbo.co.uk
c2_mad
Member #: 4215
thanks for all your opinions*wink*
Think of a rally car coming up to a hair pin, yanks on the hand brake, back end breaks free and slides around the corner.
Having too much rear breaking (compared to front breaking) will lead to a similar thing if you brake whilst cornering although maybe not on such an extreme scale.
Also as the others have said Minis have most of the weight over the front wheels (there are several minis out there where even I can pick the back end off the ground) which also makes a big difference to braking.
I know of more than one competition Mini that has the rear brake lines solder up so they only have front brakes (I'm not saying who as the rules they race under say that they are meant to have rear brakes) further I've driven a Mini without any rear brakes and I quite like the way it drove, in my opinion it suited the handling of the car and my driving style.
Finally I'm not over convinced by KAD discs, as I said I don't believe that you need much rear braking and also I reckon that you could get a set of Mini fins down to the same weight or less with a bit of machining, since there quite a bit of metal that can be removed from them.
Click here and watch*happy* 0:45s is the bit you want *wink*
