Home > Wanted > Inlet Manifold
quinton
Member #: 1911
If anyone has one lying around they want some spare cash for I'm willing to take it off your hands. After the turbo one if possible please.
I think i have a spare, i'll check tonight. :)
quinton
Member #: 1911
Cheers phil
I have one, but i've noticed there's a crack in it. I may be able to get it welded though ?
quinton
Member #: 1911
Oh has it. Right we gotta be careful as we talking probably 20psi of boost going through the manifold so the welding's gotta be spot on right? What do you recon?
It should be fine when welded. How much of a rush are you in for it ?
Phil. :)
quinton
Member #: 1911
I'm not mate. Take your time with it still gotta get the head sorted and pistons and the list continues
Cool. Right i'll get it sorted then. :)
i have one as well
quinton
Member #: 1911
Ah great stuff neil. You at the pub tonight? I'll be meeting ollie and paul there to discuss Riv Run so Could pick it up off of you then if you want?
I'll tell my mate not to bother welding it then.
Anyway, welding it should be OK. 20psi is NOTHING when it comes to these things.
quinton
Member #: 1911
Cheers for the thought tho phil.
