| Home > Technical Chat > brakes... whats good and whats better? | |||||||
6th Mar, 2009 at 06:04:09pm
well, I have been delving into the world of braking the last couple of hours, and have an interesting observation....
388 Posts Member #: 442 Senior Member Manchester |
6th Mar, 2009 at 06:12:59pm
Awsome. Good old two pots! I think ill stick with what ive got and get some better discs. |
6th Mar, 2009 at 06:14:10pm
aye, thats why my 7.5s are so fecking rock soild!
6th Mar, 2009 at 07:19:03pm
This is something I've been meaning to sort out for ages.
6th Mar, 2009 at 08:03:21pm
is that right with the pads? its not somthiing i had considered, i have just focused on the idea of all the mechanical and hyraulic ratios. I guess so though, after all F=P*A
6th Mar, 2009 at 08:09:53pm
I allways thought as far as friction goes (which is ultimatly what we are after yes?) area is irrelivent.
Edited by slater on 6th Mar, 2009. |
6th Mar, 2009 at 08:16:56pm
We had a similar discussion about clutches a short while ago.
Edited by Paul S on 6th Mar, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Mar, 2009 at 08:26:12pm
My head is hurting enough as it is trying to do some uni calculations, reading that other thread has made it 10 times worse! On 7th Oct, 2010 5haneJ said:
![]() 85 Posts Member #: 2234 Advanced Member Palm Beach Gardens, Florida |
7th Mar, 2009 at 12:01:11am
I use the KAD 6-pots with modern Ferodos and vented discs when racing with HSR. I have 5.5" mag Minilites for rains and 6" Revolutions for drys. Other vintage organizations here require the stock Cooper S calipers and discs, which I run with the old Ferodo DS 11 pads. I run 3" vents from the turn signal locations in the bodywork to the calipers. In normal (?) racing I don't notice any difference in performance, but if you get in too deep, at the limit the Cooper S brakes will fade and the car will become agricultural. I can overcome the spec tire (Hoosier) grip with the KADs on a hot dry track. I did run a few SCCA races with slicks, I never had more brake than tire with slicks. So far the KADs give me more brake than I have bravery; damn nice brakes. |
326 Posts Member #: 1323 Senior Member |
7th Mar, 2009 at 07:34:09pm
obviously big two pot calipers are the best ........
9th Mar, 2009 at 09:46:13pm
Thats good to no. Ive got kad 6pots and im hoping there great.
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
9th Mar, 2009 at 10:40:04pm
Hi there guys,
9th Mar, 2009 at 11:22:20pm
Something I forgot. The KAD 6-pots are race brakes, they have no dust seals. Road filth will get to the pistons. So they probably are fine for a track-day car, probably not suitable for high-mileage street use. |
9th Mar, 2009 at 11:50:31pm
I'm a 1 pot man well one on each side of the car.. stops well I run a supercharger and I don't care the TB is on the wrong side.
10th Mar, 2009 at 05:55:47am
Ive got S brakes with a 0.70" clyinder and it doesnt work too well. I think the Coopers had a 0.625" cylinder insted which would improve matters.
10th Mar, 2009 at 07:45:52am
The only Mini to have a smaller MC diameter was the 997 Cooper. On 13th Jul, 2012 Ben H said:
10th Mar, 2009 at 08:42:34am
On 7th Mar, 2009 carl talbot said:
who needs the brain ache with the maths ? I have a fetish for Maths. Seriously, I think that the belief that 6 pots are the best has just flown out of the window. Edited by Paul S on 10th Mar, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
10th Mar, 2009 at 11:26:30am
I have a set of Cooper S on one car and a set of KAD 4 pots on the other both with the same compound pad the 4 pots where far superior but when I changed the Coopers setup to carbon metallic pads the braking effor on the cooper s is astounding dam near lifted the back of the car off the ground. On 17th Feb, 2009 Rob H said:
10th Mar, 2009 at 11:41:20am
The math on piston area and pad swept area is interesting, but in road racing the performance becomes limited when you generate more heat than you can dissipate before the next corner. This is one of advantages of the the six pot, air gets in and heat gets out easier than a two pot. The next advantage is that the designers employed 3 different piston sizes in the caliper, the leading edge pistons are smallest, for even pad wear and it helps the pad temperatures to stay uniform across the pad. I suspect the alloy caliper dissipates heat better than the iron caliper, and I also suspect it holds more volume of fluid. Its a monoblock caliper, so it doesnt flex, and its lighter. It's blingish too. OK, that's all the good stuff I can think of, on the bad side its expensive. Meanwhile, the stock 2 pot Cooper S caliper is good even for racing, and very good if you castellate the pistons and duct air to the caliper. |
10th Mar, 2009 at 05:41:54pm
With brakes , I think heat is the key , drum brakes will work just as well as discs until the heat build up causes fade , likewise with single and multi pot calipers .
10th Mar, 2009 at 08:02:15pm
You also forget about the radius of the pads. Of you're using three small pistons, these can be spaced further from the centre than one big. Hence you can use a longer and shallower pad at a bigger radius. Same area, better leverage. Edited by Vegard on 12th Mar, 2009. On 13th Jul, 2012 Ben H said:
10th Mar, 2009 at 09:47:41pm
the bean tin type is .70 there is an bean tin on the Mk1's that was .75 but not available anyone. the yellow tag is .70 to the rear and .75 to the front. The yellow tag uses different size unions as it was a dealer upgrade when the old units failed that were .70 front and back..
On 10th Mar, 2009 slater said:
Ive got S brakes with a 0.70" clyinder and it doesnt work too well. I think the Coopers had a 0.625" cylinder insted which would improve matters. Im thinking of just swapping to alloy calipers tho! i assume they are the same as the metro 4 pots in piston area? I run a supercharger and I don't care the TB is on the wrong side.
10th Mar, 2009 at 10:04:14pm
very true,
On 10th Mar, 2009 Vegard said:
You also forget about the radius of the pads. Of youære using three small pistons, these can be spaced further from the centre than one big. Hence you can use a longer and shallower pad at a bigger radius. Same area, better leverage. On 28th Aug, 2011 Kean said:
10th Mar, 2009 at 11:49:46pm
dont they run smaller pots to deal with it.. I have been in a Zcars mini that was running Tarox 6 pots on the front and the ford rear disc conversion he was using a bean can clutch cylinder modd's with a return spring and it stopped as well as it went. he did change from .625 split AP cylinders, he wanted to push more fluid, the clutch cylinder is a .75 single Edited by gr4h4m on 10th Mar, 2009. I run a supercharger and I don't care the TB is on the wrong side.
