Home > Help Needed / General Tech Chat > Spraying engine
Mini Stevo
Member #: 239
Somerset
just wondering do you have to use any special paint?
Suppose the process is easy just bung the holes in the engine up with bits of rag and spray it bieng careful not to leave any bits in the engine. Is it worth undercoating it?
cheers, Steve
Cheers, Stevo
nutter driver
Member #: 47
Not very sunny swanage
ive always brush painted mine using either engine enamel or hammerite, never used an undercoat, just made sure all loose rust is gone, and that there is no oil or grease.
Hi Mini Stevo yes as nutter driver said you can use enamel or hammerite, this is more forgiving if your block is a little surface rusty.
however you can use Normal spray paint with indercoat, but your block has to be SPOTless for it to stay on.
yep my hammerite is brushed on, looks good and seems to stay there too. have to be careful the first few runs as it goes soft when hot but once its been hot a couple of times it seems to dry it out nice and solid.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
engine enamel from halfords works well!
alex
AlexF
adam1330
Member #: 238
essex
hammerite does the job for me aswell..
T3Tone
Member #: 252
Sunny suffolk
Brush painted hammerite, dries nice and smooth. Easy 2 clean 2:)
-MINI CLUBMAN 1380 TURBO-
hammerite every time
EP3A engine spray paint from Moss - a lovely green colour...
b12
Member #: 247
Kent/Surrey Borders
hammerite for me !!!
Some friends of mine slagg me off everytme I hammerite a engine as they say it makes the engine retain heat
Could be Bollo ?
S
TurboLessTosser
"makes the engine retain heat"
LFMAO
minimark
Member #: 19
newcastle
what your with 2 pack??
as usual Mark makes no sense at all...
Mini Stevo
Member #: 239
Somerset
I mite use hammerite then *happy*
Thanks guys, Stevo *wink*
Cheers, Stevo
minimark
Member #: 19
newcastle
whats wrong with using 2 pack ???
i reread that one before posting , hope thats ok dave .
b12
Member #: 247
Kent/Surrey Borders
TD ... I have some great mates that come up with these sort of gems "makes the engine retain heat" !!!
Rememeber the other GEM ... a intercooler will make no difference !!
TurboLessTosser
I also have a mate who comes out with some absolute gems occasionally
1) "Newton is wrong"
2) "Prostitution isn't illegal"
3) "Planes can't turn corners"
Yes you quite often want to hit him.....
