| Home > Help Needed / General Tech Chat > Got my engine and ancillaries !!! | |||||||
24 Posts Member #: 268 Member |
13th Oct, 2004 at 10:09:33am
OK guys got some pics of my new engine and the ancillaries and was wondering if u could spot anything else i need, i know that i need a fuel pressure reg, and a fuel tank with a fuel return, but can u spot anything else? cheers
13th Oct, 2004 at 10:24:04am
Fuel pipe
AlexF |
13th Oct, 2004 at 10:37:20am
Cheers Alex, any idea what sort of pump i will need? Yeah i will be DIY'ing and i got no idea what connects where yet so still got aload of homework to do... DOH
13th Oct, 2004 at 12:33:27pm
Need a few more blades for you fan... lol!
13th Oct, 2004 at 12:50:43pm
you will want a braided oil supply pipe to the turbo. the std one gets in the way of the mini engine steady bar.
13th Oct, 2004 at 03:15:18pm
i can do these if you want one. including all T pieces etc for £43. do lots more things like brand new pumps etc if you need. |
13th Oct, 2004 at 07:07:41pm
ah yeah lol, the fan... obviously will have to get onto that 1, and i will be onto you iain for some parts as soon as i get the engine to play with... as for spi tank with internal pump where bouts other than ebay will be good to look? Nick
13th Oct, 2004 at 07:16:27pm
Can throw you a fan in with the bits you need mate if you like, got some spares.
13th Oct, 2004 at 07:18:26pm
well if its going let me know... cheers!! really cant wait to start playing :)
421 Posts Member #: 245 Senior Member |
13th Oct, 2004 at 07:22:15pm
dont forget to strip it and check it all before
13th Oct, 2004 at 07:23:45pm
minisport advertised injection tanks with pumps sender etc for about 90ish quid i think not bad really as its brand new and youll probably pay close to that if you see any on ebay, mine cost 80 quid from mini scrappers no longer a series, but still 1.3 turbo.
13th Oct, 2004 at 07:25:50pm
cheers for the advice guys, its deffo gonna get a full engine check and rebuild, and im thinking it will be a good idea to have the turbo unit rebuilt? astupid question but do these engines put out 90bhp on standard boost on a solid engine?
13th Oct, 2004 at 07:40:17pm
yes they do.. book says 94bhp..!
AlexF |
14th Oct, 2004 at 10:07:31am
woah 94, hopefully can make a gain on that, is 1.3 roller rockers an avonbar phase 2 cam and an i/c a good way to go?
14th Oct, 2004 at 11:40:39am
id say yes thats a good idea. should see a comfy 100bhp with a slight boost increase. dont forget to have the chambers opened up in the head to lower the compression ratio and you'll be laughing |
14th Oct, 2004 at 01:02:46pm
Opening up the chambers in the head, where could i get this done and roughly how much would it cost? also what compression ratio would i be looking for??
14th Oct, 2004 at 01:08:11pm
Morspeed do it for about £50 just to drop the CR
AlexF |
14th Oct, 2004 at 01:11:41pm
that does sound interesting, but how driveable will it be at low revs?
14th Oct, 2004 at 02:41:53pm
More power will make it less friendly at low revs... but unless you spend all day in traffic then there isnt much point worrying about it!
AlexF |
15th Oct, 2004 at 10:40:34am
cheers Alex.
16th Oct, 2004 at 07:57:43pm
have you got a distributor for it? |
10th Feb, 2005 at 03:35:19pm
LOL, a bit late yeah i got the distributor. I also have a fuel pressure reg so its just the spi tank to go, we are looking at putting the engine in at the end of the month, so alot of posts will be going up then to make certain that what we are doing is right as we go along..
11th Feb, 2005 at 08:45:57pm
if i had to change anything on mine id fit an actuator and the bleed valve hoses as these are a pain in the arse to do with the engine in! i got my fuel pump from avonbar bit expensive but it works well and had no probs |
13th Feb, 2005 at 05:29:50pm
wot actuator would u reccomend? thanks for th advice?
