Home > Beginners Tech > adjustable boost
welshdan
Member #: 1111
s wales
hi, i have been on this site for a while. have built my engine to run at 10 psi on boost.
have not looked into detail about adjustable boost. i know that metro turbos use an ecu that controls boost from about 4 psi up to 7.
can i use a standard actuator and bleed valve to adjust from about 4 up to 10?
i know this is basic stuff but if anyone could give pointers towards fitting such a setup it would be mch appreciated. thanks
Yes you can use a bleed valve on the standard actuator to get 10psi, no probs.
tadge44
Member #: 2500
Buckinghamshire
Unless its mullered,as mine turned out to be.Fit an actuator which gives you 10lbs without boost then you can bleed it until it blows the engine -you know it makes sense !.
turbominij
Member #: 2104
Essex - UK
i dont use a bleed valve any more i use a electronic boost controller works a treat i can have 2 settings at what ever boost i want 7 10 15 18 what ever press of a button and it changes to the other one
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
welshdan
Member #: 1111
s wales
how hard is it to fit the electronic controller? whats involved? where are these available from?thanks
MarkGTT
Member #: 1194
Shropshire.
sounds good, what one do you use?
turbominij
Member #: 2104
Essex - UK
here is the boost controller i use
basicly you plumb the solonoid in line in the actuator feed and connect the clip to the main unit
the main unit then needs the following:
1x pos +
1x neg -
1x ignition +
1x pressure feed(vac/boost like a boost gauge)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=330314515182
tadge44
Member #: 2500
Buckinghamshire
As far as I can tell this is just a variation on the bleed valve technique, with multiple bleed options,electronically controlled.I only need two settings,normal and bloody hell thats quick,selected by a flick switch and solenoid.Total cost about £5 instead of £95,but it does not have the pub talk value of then expensive one.
turbominij
Member #: 2104
Essex - UK
very true however a bleed valve perminantly bleads off air where as this is closed untill("closed circuit") the dediered boost pressure is reached then it opens this minimizes the lag on the turbo as it does not need to over come what ever you are bleeding off before it can pressurise the system. aparently it also gives a more stable boost pressure (so say the jap guys)
tadge44
Member #: 2500
Buckinghamshire
Understood - thank you
but i thought that the spring and ball bearing ones do the same?
the spring pressure (user defined) keeps the bearing on its seat untill the boost pressure over comes the spring pressure and then bleeds off the air?
or am i talking shit and just thought up a new bleed valve?? haha
Yes an MBC should have the same effect.
turbominij
Member #: 2104
Essex - UK
i had never heard of these ball bearing ones how does it work like the oil pressure release valve?
If thats the case then i would agree with phil same effect keeping it closed untill the boost pressure is reached like a safty valve on a steam train or radiator cap
Turbo Shed
Member #: 30
Epsom, Surrey
a proper electronic boost controller is an electronic restrictor in the boost line to the actuator, it then monitors the boost level and adjusts it to what you have set, as such it never "bleeds" so does not waste boost pressure to atmosphire
