Home > Technical Chat > Oil temps
What is a general running oil temp ,and what would you say a maximun is?
A bit ot but younger bro has a vag 20v turbo motor and he thinks its getting too warm so needing a bigger oil cooler?
Basicly the car standard is 180bhp and his is 240bhp.
Chears lads Rick
Pass, I havent got the foggiest what a maximun is
Thanks nic.:$
Rick
Scruffy
Member #: 328
Seaford Rise, South Australia
Unless he is using it on a circuit all day I would say this is not needed - are you sure it does not have one as std? Water cooled ?
On 5th Sep, 2011 Vegard said:
Yes its a water cooled one, its also got a factory temp gauge in the car.
He sees normal running around 90 but as soon as its on boost its up to 100 but if your on power for 5mins its hitting 110-115
We did cadwell the other week , i didnt get it past 110 but i dont rev the ass off it but he reconed it went over 115 when he was driving.
Rick
I thought 120 was max for oil temp, I'd not touch it if I was him
120-130 deg c is a max from what i've heard, a tad hotter for some synthetics.
Anton
Member #: 764
Staffordshire
surely it depends what oil is being used. It might be worth speaking to the manufacturer
Si P
Member #: 912
North Yorkshire
I think its best to check against the oil spec you've got in it Rick.
Most synth's do get hot. But are tested up to about 150'c I think.
(Mobil 1 0w - 40 of the top of my head.) Its what I put in the clio.
Costco £20 for a 4.5lts.
Flash point of about 230'c.. Cool Flames.....!
But 120'c your getting up there..
Si
Edited by Si P on 25th Mar, 2009.
Hes useing millers fully sinthetic 5/30
Il have to have a look and see what it says on the tin.
Sounds like its ok though and not getting too hot.
Rick
Rick, this is the technical section ,are you lost.
Yes completeley lost carl, but i thaught id ask you technicaly minded chaps but then you jump in.
Rick
